Question about Home
I need to know exactly how to adjust the toilet tank fill valve on a Hoov-R-Line 8121-1AS or get a link to a user manual. The toilet tank fills too high and it's constantly overflowing and I have no idea how to adjust the fill valve and I refuse to call a plumber.
    Scholar:
  • 102 Answers
Most of the HooverLine fill valve have an adjustment screw on the top of the valve. It only takes about a half turn to change the level. Hope this helps.
Posted on May 13, 2010
Testimonial: "Thank you. You are correct. The plastic screw on top of the valve did the trick. At first I went to far with the screw and the tank water level went too low. But I got it just right now. Thanks. "
The toilet does not refill the tank to the water level line, as a result the float is about 20mm below the water line and the toilet is hissing 24/7. How do i adjust to make the toilet fill the tank to the...
The fill valve sounds if it is bad.Go to lowe's and get a fluidmaster fill valve(about $8) instructions included.turn off water and remove water from tank then disconnect supply tube,remove old fill valve install new,follow installation diagram,and the adjustment process to adjust the water level to correct level that should take care of your problem.
Jun 19, 2011 | Caroma toilet - water saving Sydney Low...
Toto Drake does not fill the bowl to the level of other same toilet. Water level in bowl is low.
Water Level Adjustment
1. To adjust, simply turn upper half of valve counter-clockwise to unlock, pull up till water line on valve is level with water line marked in tank, Fig.C then turn clockwise till valve snaps into locked position.
2. Turn on water supply to fill tank.
3. Tamper proof key is optional, and may be used to simply to prevent further adjustment once final setting is achieved. Fig D
Jan 28, 2011 | Toto Drake ADA Compliant Toilet with...
Toilet keeps running water in back tank keeps running over top of drain hole
You don't have to replace, You just need to adjust the fill valve. If you have the ball **** type just tight the top phillips screw. If you have the newer type, close the water valve under the tank and Push down a plastic ring at the bottom of the filling valve, Push down the top of the valve, lift the plastic ring to it's place and open the water valve.
Aug 01, 2010 | Toto Home
When the tank refills, the amount of water that is
The fill level can be adjusted by either lowering the filler valve column or bending the filler arm down. The adjustment method is dependent on the type of filler valve. Be cautious not to allow the fill level to go above the designated fill line.
Jun 21, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
I need to know exactly how to adjust the toilet tank fill valve on a hoov-r-line 8121-1AS or get a link to a user manual
There should be a screw on top, usualy plastic that once flushed can easily be turned to adjust the tank level. Usualy half turn at a time will make a pretty substantial change. I hope this helps.
May 14, 2010 | Home
I have an American Stadard Toilet that is only 2 years old. The toilet will not stop running. Could you give me some trouble shooting ideas?
There's a lot of variety in the works in the toilet tank. Assuming this is not a pressure-assisted toilet-----First understand the three valves are: 1. The shutoff valve - on the supply line coming into the toilet tank. 2. The fill valve - inside the tank, opens with the float descends, closes when the tank fills up. 3. The flush valve - inside the tank on the bottom. Common old style is a flapper on a pivot. Yours may operate straight up and down rather than on a pivot.
Three very common problems are---- 1. The chain that connects the handle to lift the flush valve is getting caught, not allowing the flush valve to close. 2. There is problem with the flush valve being able to get a good seal when it closes - could be debris or misalignment. 3. The fill valve is not closing when the tank is full, could need adjustment or there is debris preventing the valve to seat. . Here's are some steps to diagnose---- close the shutoff valve. Wait a few minutes as you watch the level in the tank. If the water level decreases, you have problem with the flush valve. To confirm the fill valve as the problem, turn the shutoff valve back on. Lift up on the float that is supposed to turn off the fill valve. If it shuts off, you should be able to adjust it - most have a +/- plastic adjustment screw. But if raising the float by hand only slows it down, you have problem with the seating of the fill valve - which can sometimes be cleaned, but more often would need to be replaced.
I hope this is helpful. Thanks for using FixYa.
Apr 02, 2010 | American Standard Home
How do I adjust tank fill valve to increase water level in toilet?
There are many different fill valves out there so it would be a little hard to tell you how to adjust your particular one without knowing the brand and type of the fill valve.
So I will give you a generic adjustment.
Look for someway/something to adjust your float in the toilet tank.
There should be a screw, moveable metal, something that will adjust your float.
Once you locate the adjustment, you can then adjust your water level in the toilet tank.
Adjust the water level in the toilet tank to be about a 1/4-1/2 inch before it flows out of the overflow tube when the water shuts off.
Good Luck, I hope this helped.
Please rate me, Thanks
Mar 11, 2010 | Home
New water valve makes ahigh pitched whistling
I had exactly the same problem. Just turn down the water pressure @ the valve on the water inlet line. While you have the toilet lid off, you may want to remove the fill valve (1/2 turn counterclockwise on the plastic nut attached to the water-in line), and clean the rubber diaphrams (there are 2). They will sometimes get gritty and this will cause some fill noises and leaking.
Oct 25, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
When flushing toilet, water spins in bowl but does not flush away. Have used plunger to no avail. Any suggestions?
It's either plugged or the tank isn't filling properly.
If it's the tank then the fill valve in the tank needs to be adjusted. There should be a screw to adjust the float ball. Back the screw out until the fill valve starts to run;let the water run until the tank fills to the fill line then turn the screw back in.Try flushing the toilet. If that doesn't work then the toilet is probably plugged.
If it's plugged you may need to rent/borrow a snake to clear the line.
Oct 09, 2009 | American Standard 2071.016 Heritage One...
Home Logo
765 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
