Question about Toshiba 52HM95 52" HDTV Projection Television
I own a Toshiba 52HM95 and recently white thin vertical lines in sets of 8 with a separation of 2 inches from each other have appeared. What could be the cause? Thanks.
  • samjunco May 04, 2010
    Very helpful and detailed. Thank you for the quick response.
  • 336 Answers
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,vertical lines,color distortion or white dots on screens. Here's a video for a samsung (It's the same technology as your Toshiba) that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q IO didn't find the DMD chip by itself but with complete light engine here http://www.discount-merchant.com/TOSHIBA-050915660-p/1172913.htm Have a blessed one!
Posted on May 04, 2010
There is a vertical black bar along the left side of my TV. It started as a thin yellow/white bar and has grown to be about 2 or 3 inches wide, blocking that portion of the screen.
The LCD wafer has gone bad, and more lines will begin to appear over time. It can be replaced but the cost may be comparable to replacing the entire television.
May 22, 2015 | Televison & Video
Thin vertical line on copies
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
Mar 24, 2014 | Canon PC-940 Black and White Copier
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
Thin white veritcal lines
I am inclined to believe that this is a DMD board related problem. It is possible that you have got a faulty replacement DMD. It is what causes the light to be reflected on to the color wheel and if some of the nano mirrors are not functional then you will see white stripes in the place of the actual pixel. Contact the store where you got it from and return it for a new board.
Let me know if you have any further queries,
Sai.
May 04, 2010 | Toshiba 52HM95 52" HDTV Projection...
White vertical line through laptop screen
The cause is a failure of the LCD, and you can fix it by replacing the LCD.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+5160+LCD&_sacat=See-All-Categories
Instructions are here
http://support.dell.com/support/edocs/SYSTEMS/ins5160/en/SM/display.htm#wp1105699
Mar 29, 2010 | Compaq Presario M2000 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Toshiba 52HM95 52" HDTV Projection Television Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
