Question about Dell Latitude D600 Notebook
Have a problem with hive files,i can install windows xp prof ok,update all the drivers with resource cd, and the system will run for as long as i need, but when i shut it down and leave it for half an hour or so, fire it back up, i get a blue screen telling me that there is a problem and windows cannot load the hive files...i have ran chkdsk /r and it has 'corrected one or more errors'but it still gives a blue screen and system/system32/config (or software, or default) error, does anybody have any ideas please
  • Dell Master
  • 4,737 Answers
Instead of running chkdsk /r you better repair the using the Win XP installation CD. Or if this is caused by virus, you better format the system after backup. There are some more ways to fix this but it'll be much complicated for you and you'll end without the desired outcome. The two process i have given you will not fail so go ahead and don't forget to backup your files if there are some which are important. good luck.. and please rate me as well. :-D
Posted on May 04, 2010
Testimonial: "many thanks for your quick response. i have already repaired it using the windows disk, but it didnt work,i will try the formatting procedure and see how i get on.. many thanks again for your help"
  • 360 Answers
Hive files are your Registry.
Out of all the computers I have ever fixed, I have only had one that corrupted the registry after a reboot on a fresh install of windows. The culprit was the hard drive failing.
The problem of yours can also very easily happen if your computer is not shutting down properly...which can be caused by software, hardware or a BIOS problem.
Reinstall windows once again, only install what drivers you absolutely need....bare minimum. Shut it off for awhile and turn it back on. If your problem still persists, then look heavily into a hardware problem. I would concentrate on your hard drive or motherboard.
Hope this helps you narrow down your problem.
Testimonial: "hi, thanks for your quick reply. i have tried three hard drives in this machine and each one is doing the same thing, so it may be, as you suggest that the motherboard is failing, i had another reply telling me to format the hard drive once i had backed up my files, so i will give that one last try, otherwise i think it may be a new motherboard...thanks again for all of your help, it's much appreciated."
  • 808 Answers
Install from another disk an use reg in out
Posted on Sep 08, 2010
My laptop will not boot, instead it goes to a blue screen that states it is not able to access the hive.
I think this is the exact error : Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION:
To resolve this issue, please follow one of the following methods.
Use the Recovery Console Tool:
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console. You need your original XP CD, boot your PC from the CD and press R when it say 'Press 'R' to use recovery console.
In Recovery Console, change to the c:\Windows folder.
Type cd system32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
i understand this looks a litle daunting, please get back to me if you have any trouble with this.
Oct 16, 2010 | Sony Computers & Internet
My tecra 8000 fails to boot cannot find config sys
Originally Posted by Don this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console2.gif.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Aug 22, 2009 | Toshiba Computers & Internet
Dell Resource CD - not working in Windows XP SP3 version
You are using the Dell Resource CD provided by the manufacturer. This CD may not work with new versions of Internet Explorer that come with SP3 installations (if you reinstalled from a Windows XP CD not provided by Dell or if you did the Microsoft SP3 update).
You're only solution would be to use your "Service Tag" number underneath, for laptops (or on the back/side for Desktops), of your computer and go to http://support.dell.com to download the drivers for your specific system. If this computer doesn't have the drivers for you to be able to go to the internet, use a second computer and go to the site. Then download the individual drivers listed (the latest dated drivers will work best).
Once you've downloaded mainly the Video, Network, Audio drivers, use a USB Flash drive (sometimes called USB Key, USB pen drive, USB drive, etc) and copy what's been downloaded onto it. Do not double click on the files while they're on the second computer.
Once on the machine with Windows XP SP3, double click on each downloaded file (1 at a time) and follow the on-screen insctructions to install the driver. You should be fine afterwards. :) Let us know how it goes, and rate us. :)
Jul 19, 2009 | Dell ResourceCD (2p730)
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Audio Problem
http://intel.driversdown.com/Intel-drivers/Intel-Desktop-Board-D945GCNL-HD-Audio-Controller-5605-Windows-Vista(32-64)-XP(32-64)-2000_77686.shtml
Intel Desktop Board D945GCNL HD Audio Controller 5605 Windows Vista(32/64)/XP(32/64)/2000
Installs the Realtek audio driver version 5605 for Intel® Desktop Boards.
IMPORTANT: Audio drivers may fail to install in Windows* XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error". Microsoft's Update for Windows XP x64 Edition (KB901105) fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
Apr 23, 2009 | Intel D945GCL Motherboard
Ethernet cotroller drivers for Win XP Prof
Here is a link to an excellent tutorial that will guide you through the process of updating drivers in XP.
It has instructions for opening the Device Manager and finding out what hardware is installed in your system. Then you need to go online from another computer, download the appropriate drivers and burn them to cd, load this cd in your computer, then update the drivers on your system from the cd. You can drag the setup files to your desktop and install them from there.
I hope this information allows you to resolve this issue. If I've managed to answer your question or solve a problem, please take just a moment and rate this post....thanks!
Mar 31, 2009 | Microsoft Windows XP Professional With...
Vista to windows xp prof., toshiba satellite l305-s5894
hello , friend its very easy to do that, steps are
1. insert bootable cd/dvd xp prof. cd.
2. But be cautious because the xp profsn doesnt contain the drivers for ata hard disk. so pls find on net the drivers for ata hard disk drivers, also update it in bootable xp profsnl dvd . recreate bootable dvd of xp with advanced bootable xp,
3. or find it from your friend with latest updates requirement. and do from it.
4. Boot from tht cd and start the installation.
5. once it i completed install all video, audio e.tc. drivers.
6. if you dont have that drivers pls download it from toshiba site by entering the toshiba serial no
Mar 25, 2009 | Toshiba Satellite L305-S5894 Notebook
Problem installing Windows XP Prof. DG31PR (BSOD)
I had the same problem. After some experimentation, I traced it the Core 2 Duo processor that I was using. I fixed the problem by switching the CPU to single processor mode in the BIOS setting. Windows installed fine. After all the drivers and the windows updates were installed, I switched the single processor mode off.
Things are working happily ever after :-)
-K Vejju
Aug 07, 2008 | Intel DG31PR Motherboard
Problem with pc
Here is the solution right from Microsoft.
SYMPTOMS
When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
CAUSE
RESOLUTION
To resolve this issue, use one of the following methods.
Determine if the file that is mentioned in the "Symptoms" section of this article is present, and if it is, rename it:
Type cd sytem32\config , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type ren software software.bak (instead of ren system system.bak ), and then press ENTER.
Oct 23, 2007 | Computers & Internet
Having problems with my compaq Persario 2500
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
md tmp
md tmp
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Dell Latitude D600 Notebook Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
