Question about Toshiba Satellite M55-S135 Notebook
Notebook will send signal to television but not the ext. monitor
Notebook screen will show icons but backlight isnt working. when set output to tv through s-video picture on notebook and tv works, no backlight on notebook. when i set output to monitor notebook goes black and monitor says that thiere is no signal input. using vga cable from notebook to monitor. i have had success on couple of occasions, but is no longer working.
    President:
  • 524 Answers
The inverter is not working you have to change the inverter for you Notebook.
Here's the link where you can go and buy inverter for your laptop.
- CLICK HERE
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 05, 2010
My Settings/Advanced/Displays, don't show, there is no setting to use any ex. screens I have 2-Inspiron 8500s my other one shows the setting display but one don't can you tell me what to do to get...
LAPTOP OR NOTEBOOK COMPUTERS HAVE A KEY ON THE KEYBOARD IN THE LOWER LEFT SIDE THAT HAS A "Fn" MARKED ON IT, SHOULD BE BY THE CTRL KEY. PRESS THIS KEY ALONG WITH AN "F"KEY, NORMALY F5, ( HAS 2-BOXES WITH A DIVIDER LINE), WILL CAUSE YOUR SCREEN TO GO BLANK AS IT IS NOW SENDING THE VIDEO TO AN EXTERNAL MONITOR. PRESSING THE 2-KEYS AGAIN WILL APPLYTHE VIDEO TO BOTH MONITORS, THEN PRESSING BOTH AGAIN WILL RETURN IT TO YOUR LATOP ONLY.
Aug 24, 2011 | Dell Inspiron 8500 Notebook
Hi, When I connect my Samsung RF711 laptop to my Sanyo LCD-42XR9DA TV HDMI to HDMI, and source the HDMI 1 input and press OK I do not get any laptop display on the TV screen at all. I have spoken to both...
I suspect that the TV can't read the signal from the computer on the HDMI port. You would get a signal from a VGA connection. (Computers send a slightly different signal over HDMI than a DVD or blu-ray player.)
In general, when connecting a TV to a computer, turn off both devices before connecting the video cables. Then turn on the TV and set it to the source (with the no signal message). Then turn on the computer. Next set the computer to output the video on the external video port. (Depending on the laptop, you may need to enable the port in the BIOS. To access the BIOS, press Esc, F1, F2 or F10 repeatedly as you turn on the computer. The key depends on the brand of computer.) Next set the video output in the OS (depends on the OS). For Windows 7, right click on the desktop (anywhere there are no icons or running programs), select Graphics Properties and set the desired monitor choice (laptop monitor, external monitor, both or extended). Click Apply and then confirm this when the display changes. (At least this works for my HP laptop on the VGA port.; my desktop lets me change monitors under Screen Resolution.)
The manual for the TV is available here: http://www.sanyo.com.au/resources/manuals/tvs/lcd42xr9da_im.pdf .
I wish that I had better news for you.
Apr 22, 2011 | Televison & Video
Does the acer 5315 have a separate video card for running the monitor?
Find the "serial-number" of your ACER notebook.
Access the manufacturer's web-site:
http://secure3.tx.acer.com/FindSystem/FindSystem.aspx?title=Information%20About%20Your%20System
and enter the serial-number, to find the complete specifications for your specific unit.
Nov 05, 2009 | Acer Aspire 5315 Notebook
I have an IBM T40 Laptop and I wanted to display my video to the television screen via the SV output. When I hook everything up, all I see on the television is the Windows Desktop background, no icons etc....
You set it to Multiple Monitors (if you move the mouse, you will probably be able to see it on the TV once it "goes out" of the laptop desktop). You need to change output mode to external S-Video.
First of all try hitting Fn + F7 key to switch to Ext-S-Video. If it works, that's it, of course. If it doesn't, TV output is not enabled.
Right-click on the desktop to bring up the Properties, go to Settings. You'll see two monitor images there, 1 and 2.
Click Advanced, then go to Displays. You'll get CRT, TV and LCD. Turn on the TV button and tune your settings.
At this point, the hotkey Fn + F7 is enabled to cycle between LCD and TV.
If it still doesn't work and you see the blank desktop, go again in Display Properties, choose LCD as Primary Display, select Secondary, and verify that "Extend desktop on this display" is NOT checked.
Nov 03, 2009 | IBM ThinkPad T40 2373 Notebook
No Signal on DVD to Samsung 2333HD Monitor/TV
I had the same problem connecting the monitor to my Philips DVD player. After a couple days trying to determine if the monitor or cable was bad, I went to the Philips user manual and found that the Video Output setting had to be specifically changed to YPbPr/Component (which I needed). Apparently the player sends the signal in only one format at a time. Hope this helps.
Jun 10, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
S-video output not working
I think your problem is because the monitor is not activated. Right click desktop, click properties, click settings. Drag the gray scaled monitor on top of the black monitor and click ok and it should send the signal to the external monitor. try draging the mouse over to it because by default the external screen will be black.
Hope this helps!
May 02, 2009 | Acer Aspire 1690 Notebook
Adding multiple monitors from my HP pavilion
you have an ext monitor connection which you can use another monitor or get s-video lead and connect to a tv.
use fn + f4(or f key that has little square icon printed on it)
this combination switches from laptop screen to ext screen/tv
Jan 28, 2009 | HP Pavilion dv1000 Notebook
ThinkPad T21 and S-Video Output
the lcd display screen has to be set to 1024x768 60hz refresh rate 1st to be able to send the signal to a tv.
then try the function/monitor on keyboard or boot with it connected.
Apr 13, 2008 | Lenovo ThinkPad T21 2647 Notebook
Using s video output
Two things you can try:
1. You need to Activate your TV OUT feature in the Monitor setting of your display properties and select Clone so as to mirror what you see in your laptop's display in your TV. As you posted, the S cable must already be inserted before powering up your laptop; and/or
2. You may need to lower your laptops screen resolution. Most but not all TV units have lower resolution capacity than monitors. Perhaps try with the lowest possible setting (800X600) and when it shows on your TV, slowly increase till it blanks out again. pressing escape would revert you back to last setting that worked. Additionally you may need to lower likewise your laptop's Color Quality setting and/or the Screen Refresh rate.
Hope that this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 14, 2007 | Toshiba Satellite A105-S4074 Notebook
The screen will not turn on
Yes these Monitors encounter problems:
1. Bad Inverter
2. Burned out Backlight
3. Power supply issues
Sounds like your inverter board is bad and backlight will probably follow!
Nov 25, 2007 | Gateway FPD1810 18.1" LCD Monitor
Toshiba Satellite M55-S135 Notebook Logo
195 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
