Stops several times with error message E10 - Washing Machines
  • 3,230 Answers
Well first of all please tell us the brand and the model number of your washing machine so we can help you in details..........
Thanks
Posted on May 04, 2010
Electrolux ewf1083 stops mid cycle displays e10 .press start button and continues but can happen up to 4 times per wash.any ideas?
We had the E10 error on EWF1083, I opened the top cover and looked into it. It's the 2 way solenoid valve and should be a easy replacement. Looked on ebay and $59 for the part ex postage
Oct 12, 2011 | Washing Machines
Error E10 keeps popping up and washer stops 2 or 3 times during cycle and have to reset it
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Here could find additioan sample guide details: fixed-frigidaire-affinity-washer-gives-e10-error
Hope helps.
May 03, 2011 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
WE are a very small non-profit and can't afford a tech to come in and fix it right now. I purchased a used Cannon NP 6030 and I made one copy fine. Then the error message ''E010 Turn copier off and then...
There are several things to try for the E10 error. E10 indicates " main motor lock, main motor rotation sensor,main board". It's a general fault which can be caused by
  • Dirty Corona wire
  • Dirty Drum
  • Dirty Optics on mirrors/glass
These would be the first things to try. After that, you're looking at a bad main board. Hope you find this answer to solve your problem.
Nov 16, 2009 | Office Equipment & Supplies
USB Emergency
myself satish i am having e10 6gb iriver with me now i am facing problem emergency USb plz. get this solved this for me facing since long time
Jul 03, 2009 | iRiver E10 Digital Media Player
EFO, E10 error Message
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
E10 error on Frigidaire GLTF2940ES
I searched the internet for a list of error codes for the washing machine. The E10 error code indicates an interuption in water supply among other things. We checked the supply lines and found that the screen on the cold water line had been blocked by sediment ( we have well water,and just replaced the pump).
Nov 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
E10 error and fabric softner
Close your inlet valve at the wall. Unscrew your washer hose to examine any blockage in the small filter screens; clean out thoroughly and refit carefully, check for any water leak on opening the valve fully. If you have 2 inlets for the machine it would be good to get an F or Y adaptor.
Pl rate if helped................
Jan 11, 2008 | Frigidaire GLTF2940ES Front Load Washer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
