Question about Gateway Computers & Internet
WOULD LIKE TO ADD SDRAM 128 PC133 TO UPGRADE SYSTEM ON GATEWAY ESS 500
    Scholar:
  • 91 Answers
Go to Newegg.com and search for your specified RAM and buy it when you get it just tack off the side of your case and pop in the stick(s) where you see the other RAM sticks (usually close to heat sink fan and power supply/ optical drive)
feel free to ask more if you must.
Posted on May 05, 2010
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
My gateway essential 400 cant run newer programs **** *** window 7... or explorer 8... or flashplayer 10... how can i upgrade my computer 2 make it run these programs ? a new hard drive ? or what do i do...
You can add hard drive if your system doesnt have enough space for the new programs. If the new programs installs well but is running slow or not starting, then you will have to upgrade your RAM and for better performance, fix one graphics card suitable for *********** board. If you can spend more, Upgrade *********** board and processor.
Thanks
Sherbaz
Sep 20, 2010 | Gateway Essential 400 PC Desktop
How to install upgrade sdram 128 pc133 for gateway 500
PC 133 Max ram for your model is 512MB - two 256 Memory sticks. Open the case, remove the menory in there (one clips on the side of each module) take note of the way the module comes out - replace with your new ones - reboot and that should be that.
May 10, 2010 | Gateway Essential 500 PC Desktop
RAM upgrade for Gateway model MFATXNIN NMZ 300L?
The system takes PC133 SDRAM, as far as i know without performing a BIOS flash it can take up to 1GB (2x512MB) most of these PC's are restricted to 2x256 so a BIOS flash could be imminent in this case.
Good luck
Jun 19, 2009 | Gateway 300 C PC Desktop
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Laptop doesn't recognize new ram
I would guess that you need PC 133. Some manufactures that were using SDram at the time required PC133 while others would require but allow you to use PC100.
This is the requirement for your laptop from www.crucial.com
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot.*
Hope this helps
Apr 09, 2009 | Gateway Computers & Internet
Memory upgrade
First step : Make sure the memory you purchased meets the following specifications
"168pin PC133 SDRAM DIMM" which should be easily accessible from wherever you bought it.
If not, then you can find memory here. that the company guarentee's will work with your system. Also - You want to make sure the memory that was in your system to begin with is identical to the memory you are sticking in it to get it to 512MB Systems that are this old with "PC133 SDRAM" are very picky about what kind of ram you stick in them. Make sure wherever you purchase your memory from, has a guarentee that it will work in the make/model of your computer.
Mar 14, 2009 | Compaq Presario 5000 PC Desktop
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
