Question about Toshiba 52HM95 52" HDTV Projection Television
Thin white veritcal lines
I own a Toshiba 52HM95 and recently white thin vertical lines in sets of 8 with a separation of 2 inches from each other have appeared. The bulb is new and the DM board has been changed as well. What could be the defective part causing this?
  • 4,889 Answers
I am inclined to believe that this is a DMD board related problem. It is possible that you have got a faulty replacement DMD. It is what causes the light to be reflected on to the color wheel and if some of the nano mirrors are not functional then you will see white stripes in the place of the actual pixel. Contact the store where you got it from and return it for a new board.
Let me know if you have any further queries,
Sai.
Posted on May 04, 2010
Testimonial: "Thank you kindly I will do exactly that. "
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Thin vertical line on copies
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
Mar 24, 2014 | Canon PC-940 Black and White Copier
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
Solid thin horizontal line
Check for excess screen voltage. Adjust the screen control to eliminate these vertical retrace lines. [Thin white line acorss the frull screen at about 1 inch apart.]
Mar 10, 2012 | Televison & Video
Black vertical line 2" wide with a very thin green line
The black vertical line is caused by a leaking capacitor, Check and replace poped capacitor with a new won and it will work fine again. No worries.
Thanks for using fixya.
Jun 27, 2009 | Panasonic Televison & Video
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Thin horizontal line
Solder bad connects in vertical circuit,especially vertical output
IC pins.................T.
Dec 26, 2007 | Toshiba 35A44 35" TV
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Toshiba 52HM95 52" HDTV Projection Television Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
