Question about Garden
Mtd yard machine model# 13am762g752 wont pull hill with PTO engaged
3 Suggested Answers
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
MTD GOLD LAWN TRACTOR WHEN ENGAGE PTO AND LOWER DECK . SLOWS DOWN TURNING BELT SLIPING
Belt is worn out and needs replacing or maybe the jockey tensioner is not operating on the belt hard enough to prevent slippage. If its all in good condition get a good DIYer or mechanic to have a look. If not its down to your local garden machinery shop.
Apr 27, 2015 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
My mtd 13ap625k730 won't allow the blades to engage. it has the pull switch on the left of the steering wheel.
check PTO turn switch on pull out pto or blade switch &push in a few times while doing this listen for clicking sound if click belt is off if no click pto is bad some r not cheap if pto is bad & u don't want to repair just get rid email me i maybe interested rileynickey@yahoo.com
Thanks hope it works
Aug 10, 2014 | Mtd Garden
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Pto on MTDMOWERVSLOW model 670 is slowxto engage
Do you hear it kick over immediately when you pull the pto switch? Is it slow to build up RPM's of blade? I need a little more info. Could be bearings on deck going bad causing a slow rise in RPM's of blade.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 01, 2013 | Yard Machines Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
Aug 14, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
