Question about Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer
The right tire wont turn something is wrong inside the hydro tran
Toro zero turn lawnmower will turn right, but wont turn left it is not turning the right wheel at all, it has something to do with the hydrostatic transmission not pumping i need help the belt is good that drives the pulley on top of tranny but no movement from right wheel. lawnmower will only turn left, cant mow in a straight line. there is plenty of fluid in the hydro tranny the gears look fine but its not pumping any fluid inside to turn the axle which turns the wheel plz help.
4 Suggested Answers
SOURCE: Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Good luck and be careful!
Posted on Jul 02, 2010
  • 4 Answers
SOURCE: Wheel came off. Can I replace just axel instead of hydro transaxle?
The hydro Transmisson Is not the easyest to repair. That is probably way they said that. plus the labor whould have been $350 to $500. So most shop won't repair them.
Find A break down on line so you can see what your getting into.
Posted on Aug 04, 2012
SOURCE: My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Posted on Aug 06, 2012
Testimonial: "Thank You very much for your support on this matter. "
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Apr 23, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Cant turn toro time cutter to the right
You might want to post this question in the lawnmower section so that the proper expert sees it.
Sep 02, 2012 | Toro Mowers - Time Cutter SS4235 42""...
Aug 04, 2012 | Toro Garden
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Was mowing and the mower wouldn't let me move forward backward left or right. I walked behind the mower and found a coil with a hook piece underneth. Bought a new coil but don't know where it goes....
sounds like the hydro release rod, at back bott of mower, what this does is releases the hydro so you can push the mower around, then you have to release this and then your hydro works
Aug 02, 2011 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Tire on toro lawnmower has de flated how do i re
Pull it off and take it to a tire shop or full service station and have it checked for leaks and repaired
Sep 16, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 42''  Zero Turn Lawn Mower 22hp Kawa Consumer Logo
351 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
