Question about Zanussi ZJ1217 Front Load Washer
How to change door seal on Zanussi ZJ1218 washing machine
What are the steps to change the door seal.
I do not know how to get the old seal off
  • 269 Answers
I hope you have small hands,and you are pretty handy with them cos these seals are tricky if its your first.
First remove the nylon clip around the front of seal it will pull off from bottom.then release outer rubber,then you have to just get your hand or fingers to pull at inner rubber,there is a spring around inner rubber lip but to make things awkward there is also a concrete counterweight around this.Once you have old seal out get new one and wipe some fairy liquid around inner lip to refit make sure pointy arrow is at the top.This is the tricky bit and hard to explain but you can only do it by feel and keep trying to get a part of inner lip over casing lip once it starts it can go easy or hard you may have to try a couple of times until you can feel it is on all the way round.Once on the spring has to be fitted its also tricky,start by door switch and put a long screwdriver thru. hole for door catch try to hold with knee or get help.Work it around keep screwdriver in until spring is nearly on keep hand on spring then gently try to remove screwdriver make sure spring on fully,now fit outer seal lip and fit nylon clamp.You may find it easier to tilt machine back slighty.I do this for a living and it can go easy or hard.Best of luck.
Posted on May 05, 2010
Zanussi fl 1084 washing machine door seal. How do I replace the rubber seal?
the seal comes in a shrunken size use a hair dryer to stretch it on to the door lip
Dec 03, 2013 | Washing Machines
Fitting new door seal
Hello,you mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install
Thanks
May 28, 2010 | Zanussi FS1155W Front Load Washer
IS IT EASY TO REPLACE THE DOOR SEAL/GASKET ON ZWF1430W
it is very very difficult to replace the door seal on a zanussi washing machine, its best fitted by an engineer
Feb 03, 2010 | Zanussi ZWF1430W Front Load Washer
When i go to press the start button it comes up with a ERR message i have a zj1218
what error message do you get? normally the error message appears when someof the component is jammed and not able to function or is gone faulty.this can be detected by the error message it shows.
Dec 28, 2009 | Zanussi Washing Machines
How to change door seal on zanussi fl 1080 . how do i remove old torn one and fit new
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
Thank You for contacting Fixya.com
Aug 03, 2009 | Zanussi ZWF1440 Front Load Washer
Change the door seal
Not sure if its the same type but I just changed the door seal on a Zanussi ZWF1221W washing machine. It was a lot easier than I was expecting but this way does take a bit longer. Before starting disconnect the mains and water supply and drain hose. If possible move the washing machine out so you can get around it.
First I used a small flat head screwdriver to open the teeth on the outer door seal clamp that holds the seal in place. The old seal then peels off the front of the machine. You can continue the process without taking the front of the washing machine off but it is much, much easier to take it off if you can.
To remove the front panel unscrew the two bolts at the top corners of the back panel and slide the top cover off towards the back and lift it off. Then remove the two bolts that attach the plastic control panel to the front of the machine (either end of the top, front edge), remove the detergent dispenser drawer (you need to push down on a lever at the back) and take the screw out of the front of the machine (revealed when you take out the detergent drawer). Then carefully remove the control panel and the two bolts that hold the front panel on.
Then (very carefully as washing machines are heavy) lie the machine on its back and remove the three screws from the bottom that hold the front panel on. Then unplug the cables on the inside of the front panel that operate the door lock (its a plug with a plastic cover - just pull it out but don't pull the wires!).
Now you can lift the front panel off which is the key to making this job really easy as you're not trying to fit the new seal through the door which makes it really tight.
With the machine still on its back find the spring that stretches all around the seal to hold it on the drum and remove using a flat head screwdriver to pull it out of its groove. You can now pull the old seal off.
It's a good idea to put some fabric softener or liquid detergent around the edge of the new seal to make it easier to fit on to the drum at this point.
Find the arrow that points to the top and starting here attach the groove of the new seal to the plastic drum all the way around. You have to press quite hard but you can tell when its properly attached to the drum. Once this is done replace the spring so it sits in a groove on the seal holding it to the drum.
Now replace the front of the panel of the machine by doing the reverse of all the earlier steps (remember to reattach the door lock) and stand it back up on its feet (careful it's heavy). You can now replace the top panel of the machine (slide it on and replace the two screws).
With the washing machine back upright you can attach the front of the seal to the door opening of the front panel (the arrow should be pointing upwards). Then you can reattach the clamp that holds the seal around the door opening and then secure the teeth on the clamp so it's tight (I don't know if it matters where around the seal the clamp goes but mine's at about 7 o'clock).
Now all you need to do is reattach the drain hose, water supply and mains and test it doesn't leak. A rinse cycle uses the most water apparently so it might be worth using that.
Hope this was useful.
May 23, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi fjr1454w door seal change.
with both clips,< locking rings > removed seal it is removable by just working it off the drum slowly,< there is overflow tube in front bottom side to disconnect also>. It is very important when installing new one that you put it in the same positiont as old one and lock rings go on same as well.
Apr 26, 2009 | Zanussi FJ1454W Front Load Washer
Mouldy Door Seal
Use tilex to remove the mold. Then see what happens. If the mold comes back right away it may be a problem with the rubber gasket not seating as it should. Let me know. And please rate my solution. thanks.
Feb 02, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi ZJ1217 Front Load Washer Logo
450 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
