Question about Nokia E61 Smartphone
Nokia E61 Boot Failure
Nokia E61 is able to start up and get to the 'home screen'. Then after displaying the 'home screen' for 5-10 seconds, it goes back to the white NOKIA screen and attempts to restart, but then seems to get stuck in an endless loop.
  • guardic May 23, 2008
    I have the same problem. DonĀ“t know how to fix it. Anyone can help. I tried all the resets (Soft, Hard) and nothing happened.
    Problem Solver:
  • 6 Answers
I had this problem once. My problem was due to a file (currupted) in my memory card. I found this out by restarting the phone without the memory card. once the phone was up and running, i looked for the damn file and deleted it...
Posted on Jun 01, 2009
Once powered on it goes to black screen and says - INVALID SYSTEM DISC,replace the disc, and then press any key.
Are you sure the BIOS is set to boot from hard disk?
It looks like it is trying to boot from network (PXE) and then from floppy disk.
Jan 04, 2014 | Computers & Internet
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
Pxe e61 media test fail check cable
what error message are you receiving on the blue screen? if it resets to fast start typing f8 at boot and in the advanced menu, toggle down to do not restart on system failure. write down the hex code (0x00XXXXX) and report back. What version of windows are you running? have you tried to press f2 or f1 or whatever key it is to enter setup on your laptop @ boot and disable network boot?
Jun 11, 2012 | Toshiba Satellite M45-S2653 Notebook
STILL SAME PROBLEM
Sounds like your hard drive is either dead or the cable or interface is not making a good connection. The computer cannot read the main hard drive that contains the master boot record and the computer is searching for a boot device. The pxe-e61 is the computer searching for a network drive to boot from. It then goes to the next device in it's menu. Need to check the hard drive and all cables and / or interface connections. Go through the BIOS settings and make sure the computer default settings are reset.
Jun 18, 2010 | Acer Aspire 3680 Laptop
My laptop isnt working.as soon as u turn it on a black screen comes up and the message display says PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM!! how can i fix it
It goes to a network boot rather than booting straight to the HDD. restart your computer and press f2 immediatley. you are now on the BIOS page. check if your hard drive is detected and if not call Lenovo to have it replaced/repaired. if it is detected, after the PXE error, your computer should boot up just fine.
Jun 05, 2010 | Lenovo 3000 G530 Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Nokia E61 Smartphone Logo
338 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
