The RC500 just shuts down and when you press the power button it is dead if you leave for a time up to a day sometimes it boots up fine and other times you power it on and it can takes 2-30 seconds and shuts down again without warning i also know of at least 1 other machine with the same fault (could this be anything to do with the power supply if so what type of replacement do i need)
Many Thanks in advance
I have an RC500 which displayed similar problems. I replaced the power supply and this fixed the problem.
Hi
The wattage says it's a 200Watt
The earthing looks OK
and the Power is supplied via the speaker cable (power supply to the Speaker then a kettle lead from speaker to tower). I was thinking maybe change the power supply for a higher wattage?
Many Thanks
Hello im dhecz, i have also Acer Aspire RC500 Desktop, the problem is similar, after 2 to 5 hrs using the pc it will shutdown and never open again,
after 2 days sometimes it works and shotdown again, i try to turn the power supply fan, the pc works... my idia is to change the power supply is it right.. please help me...
thanks..
