Question about Frigidaire FEQ1442ES Electric Dryer
Not working My dryer will not work for more than a second. When I turn it on it beeps three times then turns off. This is no the first time that this has occurred and the last time it just got better over time. Is there anything else I can try to get it to go through a complete cycle?
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryernot working - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 06, 2010
How do I remove auto door locks
  1. Put the key in the ignition and turn it to on.
  2. Press the Unlock button three times.
  3. Turn the ignition off.
  4. Press the Unlock button three more times.
  5. Turn the ignition back to on.
  6. The horn should beep once. This tells you that you're now in programming mode.
  7. Press the Unlock button, then press Lock again. The horn will beep once to tell you that Auto Lock was deactivated. It will beep twice if you're reactivating the system
There are many ways, I'm not sure which one will work on your car. I answered the two ways. I hope it works.
1. Open the driver's door and put the shifter in Park
2. Turn the ignition to On (II).
3. Press and hold the unlock side of the master lock switch for five seconds until you hear two clicks.
4. Within five seconds, turn the ignition to the Lock position.
Mar 24, 2017 | Cars & Trucks
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
Dryer heats for 5 minutes then no heat, but keeps tumbling
Perhaps the flame sensor is not working. If it does not sense heat, it will shut off the gas. You might go online and search for a manual to help you troubleshoot, or go to:
http://www.repairclinic.com/
for troubleshooting help and parts. I hope this is of help to you.
Jan 16, 2014 | Dryers
Frigidaire dryer faqe7001lw blinking lights
Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
Apr 07, 2012 | Frigidaire FAQE7001LW Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
I have a whirlpool duet gas dryer that will not turn on. When I press the start button it makes a beep three times then the lights go off.
I had the same problem with mine. As it turned out the dryer door wasn't completely shut. You really have to push them hard when they are brand new and you should feel a second "click" when it pops in all the way.
Jun 12, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer turns off after 30 seconds and beeps six times (over and over.....)
other than a good lint cleaning by dissasemble and if not then replace the motor
Jun 23, 2008 | Frigidaire FEQ1442ES Electric Dryer
Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Oct 10, 2007 | Samsung Digimax S700 Digital Camera
Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Jul 16, 2007 | Kenmore 67082 Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
102 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
