Question about Kenmore Elite HE3 Steam 8674 Dryer
My dryer is not heating up is there anything I should check before I call a repair person
  • Kenmore Master
  • 43,501 Answers
If you have a gas dryerMy dryer is not heating up is there anything I - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
DryMy dryer is not heating up is there anything I - 2_bing.gif="http://www.fixya.com/support/t4701085-no_heat_from_dryer#">Troubleshooting Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
Frigidaire Model FEZ831CAS3 insufficient heat?
Without looking at the dryer in person best I can suggest based on years of experience with this particular complaint, is that one of the 2 heating elements is burned out (yes, you can have one burned out while the other still works. If you have no experience in repairing dryers or other large electrical appliances, I would recommend finding appliance repair person locally who may do it for a reasonable cost for you, as usually need to disassemble the dryer to get behind the drum to access the heating elements.
Sep 12, 2014 | Dryers
Lg dlex7177wm heating element
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
This is a specialised job and should only be attempted by technically competent persons.
Mar 13, 2014 | LG DLEX7177 Dryer
Dryer won't heat
Odds are the Heating element is out. Only repair is to replace it.
Oct 29, 2012 | Maytag Dryers
My bosch dryer is not heating. we've cleaned out the vent and reset the button on back. should we call a repair person?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Bosch Axxis WTA4400 Dryers
Dryer is going around but there is no heat? What should I do?
check you household fuses/breaker if 1/2 tripped or you have a bad heating elment or a thermal fuse opened remote chances are a faulty time but check the 3 possibilties then if not a repair person is required.
Feb 13, 2011 | Kenmore Dryers
Our dryer is not heating up. Is there anything I can check before I call in for a repair? Thank you
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 12, 2010 | Kenmore 85871 Electric Dryer
The dryer does not heat up. everything else works.
Sounds like it mmay be the heating coil or heating element. You have to have a repair person to check it out.
Nov 12, 2009 | Whirlpool Dryers
Whirlpool gas dryer two years old does not heat.
If you remove the rear cover on your dryer after unplugging it, look for a small white piece of plastic about 1.5 inches long with two wires attached to it. This is the fuse. Can I help with anything else?
Eric Campion
Feb 16, 2009 | Kenmore 73952 Gas Dryer
My electric whirlpool senseon dryer won't heat
lint screen on top///repl/thermal fuse in rear of dryer, if screen inside dryer remove front bottom panel, next remove blower housing on top off is the other thermal fuse ,, gurantee fix
Nov 29, 2008 | Dryers
Hotpoint ctd 40 is not heating up. It goes through a normal cycle for about an hour without heating despite selecting the high heat setting. After about an hour the lights of time delay, high heat and the...
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
http://www.repairclinic.com/0088_8_1.asp
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 04, 2008 | Dryers
Kenmore Elite HE3 Steam 8674 Dryer Logo
133 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
