Question about Sharp 27F-640 27" TV
What does the OPC and green leaves type things that turn into flowers mean
  • James Davies Jan 12, 2012
    I had the same question on my Sharp Aquos. From what I can gather it is a room light sensor.
    james.davies@acsalaska.net
  • 122 Answers
Is the economy energy save mode of television
Posted on May 05, 2010
Why are my tomato plant leaves staring to curl inwards, no visible sign of disease, maintaining watering etc.
go google and type in -- problems with tomato leaves curling--
there are heaps of sites with good advice on the problem and what to do
Nov 29, 2016 | Garden
What is the most realistic type of artificial flower?
The most realistic looking flowers are made from silk.
Jan 14, 2013 | Home
Is it normal for opc and the green leaves to flash across my screen on my sharp tv?
You can turn this feature of in you menu. It is adjusting to change in roomlighting when you see this come on. Look in your menu for OPC on off setting under features menu.
Jul 09, 2011 | Sharp LC46SB54U 46 in. LCD TV
So when i turn on my sharp hd it turns off then the opc light comes on! Then the power light and opc light keep flashing!! Alls i want 4 it to work? Plz help
The television has gone into a coma. It is going to need to be serviced or replaced. The blinking code is a pattern. If you look at the power light and the opc light separately and independently, you can acquire the blinking pattern. Cover opc and look at power only. Note how many times it is blinking before it pauses. It might just blink steadily. Next cover power and look at opc alone. Note how many times it blinks before it pauses.
Depending on which model you have it might work if you leave the television unplugged overnight. The next day plug the television back in and wait for the blinking to start. Hold down the power button on the side of the television until the light stops blinking and turns red (usually right away). Let go. Press and release the power button once more and the light should turn orangish and then green. The television should turn on.
You can call Sharp and have a case file created and try and INIT with the customer service representative.
Mar 07, 2011 | Sharp Televison & Video
What is opc that pops up about every 10 Min
OPC is optical picture control. The television is adjusting itself to the lighting in the room. Even if someone walks in front of the television's sensor it will start to adjust and you will see opc on the screen and green leaves.
You can leave the feature on without the opc and green leaves appearing on the screen. Press the menu button. Scroll down to OPC. Press enter. Scroll to on. Press enter. Press menu to exit.
Sep 03, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Replace belt CG
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
May 28, 2009 | Tally T8106 Laser Printer
TALLY GENICOM 8008
The SVC E9 error indicates a 'BELT MARKER' error.
This means the printer is not detecting the OPC Belt as rotating.
This error can be caused by a damaged OPC belt, you can check this by removing the OPC belt from the printer and look at the OPC belt it should have a smooth green coating if there is damage to this belt it may cause this error.
The error can also be caused by a damaged 'Transfer Belt' when the OPC belt has been removed from the printer look inside the printer where the OPC belt used to be located you should see a black belt towards the back of the printer, if this belt is damaged it can also cause the error.
Ensure the OPC Belt locates in the printer correctly.
If the OPC belt and Transfer belt look to be free from damage and a are located correctly in the printer you may have a faulty belt marker sensor or faulty OPC belt.
You can try substituting the OPC belt for an alternative one if you have this available to see if you can narrow the problem down to the sensor.
Jan 23, 2009 | TallyGenicom 8008 Laser Printer
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
WHEN FLAT SCREEN SHARP LCD IS ON .. BLIKNING ON BOTTOM OF SCREEN SAYS OPC
Dec 08, 2008 | Televison & Video
I cant even find the apples... Enchanted Nintendo DS
okay. everytime you come around a patch of brown/green laying on the ground, those are leaves, and in some of the leave patches if you sweep it up with the stylus, thre will be apples in it.
Nov 22, 2008 | Nintendo DS Console
Sharp 27F-640 27" TV Logo
873 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
