Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Sony KP-57WV600 seven red blinks per interval.
  • 1 more comment
  • hndrx Mar 26, 2008
    Is there a way to order parts or fix this?
  • Jay2008 Apr 04, 2008
    I was looking at TV and suddenly the screen went blank but the volumn can still be heard. I tried unplugging it for 15 minutes but the TV would only turn on for a few and off it went again. So now it's sitting in my livingroom like a paper weight. I can't afford to have someone come out for $40 or $50 bucks an hour. Before the TV went blank the TV had these noticable green arches in the back which was a bit annoying but I tried to deal with it.
    I was thinking the blinking was a code. Althought you mentioned RED blinking I thought the blinking lights on my TV was green.
    Thanks
  • hndrx Apr 08, 2008
    This site's instructions fixed my problem.
    http://www.somelifeblog.com/2007/06/sony...
    hndrx
You said " seven red blinks per interval." thats not the same as red lines in the screen...
Posted on Apr 09, 2008
    President:
  • 4,402 Answers
· 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
Posted on Mar 26, 2008
KP-57WV600 red led blinks 5 times
Power supply regulator section has the fault. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center. If you wish to get more details about these kinds of fault, check this link.
Mar 14, 2013 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 different colored images red,
Ur convergence is dying,well be dead soon.These problems cause byconvergence.Blurry coloring,3D images or misaligns colors.Repair this must replaced 2 convergence ICS and all it resistors.The shop well cost U 300 for parts and labors.
Feb 09, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony wide screen projection tv model kp-57wv600 problem. Sound with no picture. Stanby red light blinks seven times? What parts do I need to repair the problem. Thanks ,Gary
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Jul 19, 2009 | Sony KP-57WV600 57" Rear Projection...
My picture is green the it shuts off with light blinking in front
that's very hard to fix, you need to monitor every test voltage pin if is in normal. try also replace crystal capacitor thats one monitor with the jungle IC.
Apr 30, 2009 | Sony KP-57WV600 57" Rear Projection...
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
Dec 06, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP 57WV600
how many times does it blink?
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
Blue to Black screen on Sony KP-57WV600
i too have 57wv600 and your problem is same as mine VOLTAGE withen tube is off ...this is common problem sony knows full well and will not tell us this voltage can be adjusted with a philips screwdriver i had blue lines then solid blue then shut off...7 blinking lights ...went to this site followed directions (too simple)and now i have perfect picture.serviceman said i needed new tube.b.s. ...so never change your tube it is not the prob!!!!!!!....go to www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html read post(comment) near bottom of page by paul t dated 12/26/2007 and instructions on how to remove our front panel is fully explained ...a screwdriver will fix your problem I guarantee it.....
Dec 28, 2007 | Sony KP-57WV600 57" Rear Projection...
No picture or sound - Error code with Six blinks
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Sep 24, 2006 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
454 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
