Question about Watts Onan Portable Generator - 5000 , Model# 6500
I have a onan propane gen. in a rv that starts right up ,but as soon as you let up on starter button it quits.hit the button over and over same thing starts and quits ,hold on button and will stay running. thanks bob
I had this same issue. I replaced the control board. Works fine now.
Posted on Aug 08, 2010
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
My onan 2.8 gen. starts but quits when i let off the starter button, what can i do to fix it
maybe old gas or dirty carburetor first replace the gas if nothing happen open your carb and clean the pilot of the carb its one small screw w/holes inside most times get clog
Apr 14, 2013 | Onan Cummins 2.8 KVD-2090 RV QG 2800 RM...
I have a onan 2.8kvd rv gen. replaced the pcd and it still does the same thing push the starter button in and hold to keep running
You need to make sure you have voltage from the stator windings, this feeds abck to the control board. Have the rotor and stator checked, and brushes and skip rings
Apr 01, 2013 | Onan Cummins 2.8 KVD-2090 RV QG 2800 RM...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Onan 5500 RV generator starting issue
Sound like a dead battery, or poor battery volatge getting to the unit. The clicking is fuel pump and or solenoid trying to pull in.
Sep 12, 2012 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
I have a onan 6.5 emerald gen,when you start it it quits as soon as you let go of the start button, will run fine while holding start button on,then quits when you release,please help,maybe field not...
More likely the switch is bad, and only make run contact when in the start position.
Easy to test the switch continuity with a ohm meter when it is not running.
May 06, 2011 | Watts Onan Portable Generator - 5000 ,...
Watts Onan Portable Generator - 5000 , Model# 6500 Logo
305 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
