Question about Rowenta Commercial Garment Steamer - White
My Rowenta IS 7850 is not producing steam however the unit appears to be on. Please help.
brnspncr
  • 67 Answers
SOURCE: MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Posted on Aug 04, 2009
  • 142 Answers
SOURCE: Hot hose but no Steam
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
Posted on May 19, 2010
heatman101
  • 43501 Answers
SOURCE: ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
rickead1
  • 1998 Answers
SOURCE: MY problem seems to be
Steam irons need a certain amount of mineral in the water for them to operate properly, but too much mineral, iron, or organic matter can be disaster. the loss of steam is from usually from a barrier or o-ring or some sort of insulating material it has to be sealed because if it is not the the steam will not build up the pressure required for adequate cleaning power is your iron leaking any water anywhere? if you have a water leak try to seal up the leak if you have any further questions please message me back and please remember when our chat has concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Posted on Jan 08, 2011
SOURCE: MY ROWENTA 1550W UPRIGHT STEAMER NO LONGER
I have a Rowenta garment steamer. It will turn on but no steam comes out. Does it need to be cleaned from the build up of iron, etc. from the water? If so, how do I go about this?
Posted on Jan 10, 2011
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
The tank in my rowenta iron is producing steam but the iron is not producing steam
Yes the iron needs to be cleaned. They do have a descaler to clean. the Steam valve with a electronic switch is broken, that is what opens and lets the steam out of the iron when you press the button.
Google Rowenta repair Centers.
Jun 30, 2014 | Rowenta DG5030 Iron
I purchased a rowenta 1600w effective iron about 3 months ago and now everytime I iron after I plug it in the light for steam won't come on and if it does it doesn't even stay on steam for me to finish a...
Possible that there is corrosion inside the steamer unit . The best is to keep filling and puttingthe set on till the dirt ceases to come over.
It can be due to even some foreign particles that is lodged in and making is combine with steam to produce the dirt colour.
If you can use a flexible bowden to clean into the holes just to see if there is any block it will be useful.
Sep 09, 2010 | Rowenta Irons
ROWENTA AIRLIDE MODEL #DX1900 IRON WILL NOT
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 12, 2010 | Rowenta Irons
My steam iron does not produce steam it heats up good but no steam comes out
heatman101
May 29, 2010 | Rowenta Steam Generator DG050 Iron
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
Jul 25, 2009 | Rowenta DX6700 Iron
Rowenta Commercial Garment Steamer - White Logo
224 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
