Question about Car Audio & Video
Peugot boxer van need radio code - Car Audio & Video
  • Car Audio & ... Master
  • 4,869 Answers
Try here for free advice and code
ukbookshelf.co.uk
Posted on May 04, 2010
Where is the horn located on an 2009 peugeot boxer
Anon, I am not familar with this vehicle, so I searched the net for horn replacement of your vehicle. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
mendmy com How do fix replace horn on my peugeot boxer 2 van Vehicles Vans...
Horn not working
Boxer horn fault Motorhome Forums Motorhome Discussion Motorhome Chat
Jul 14, 2016 | Peugeot Cars & Trucks
Any help for a code for radio for peugeot boxer with blupukt ducato cd serial BP7640377316 prod nr fiat Peugeot boxer 2003 motorhome
It doesn't need any code - that model needs vehicle number (VIN) coded into it by service interface (Peugeot Planet or Diagbox).
May 28, 2015 | Brodit ProClip for Peugeot Boxer 2007 -...
Lost car radio code for peugot 306 vin number vf37akfwf33226136
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Peugot service centre and get them to enter this code for you.
Sep 04, 2012 | Acura Car Audio & Video
Radio code peugot 206
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Peugot servicecentre and get them to enter this code for you.
Jun 03, 2012 | Car Audio & Video
Need a unlock code for phillips 1999 peugot 206 many thanx
May 04, 2012 | Car Audio & Video
How to fit a temp sensor to a peugot boxer van
Hi, Most engines have a temp sensor on the cooling system.(radiator or engine block) You can replace the old one if its not working.
Good luck.
Apr 05, 2012 | Cars & Trucks
I have a peugeot boxer van and need code for radio
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Please quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
Jan 21, 2010 | 2006 Peugeot 504
Blaupunkt GMBA radio to boxer van discnected to
The instructions should be one of these
http://www.radio-code.co.uk/post_in_radio_code_model_selection.php?m=Blaupunkt&search=peugeot&Submit=Search
Oct 16, 2009 | Blaupunkt Car Audio & Video
Boxer van gear select problem
need to feel it ,could be clutch ,if it goes in without the running then its the clutch.But i think your problem is more like the linkage and if its a builders van,then you could have rubble dropped down inside the gearchange boot.???Boxer isnt the gearchange on the dash on this model??if so then the problem could be the linkage cable ,--they get a bit rusty and sticky and you can only buy a complete pair as one unit .Try oiling with a proper oil can and some engine oil ,and not that obnoxous fish oil wd stuff
Sep 09, 2009 | 2005 Peugeot 405
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
