Question about Siemens SpeedStream 2624 Router (936-2624-001 kit)
Siemens se 587 router
I have recently purchased an apple computer, the problem i have is that i cannot connect to the internet [wireless] i have spoken with apple and my provider tiscali and am getting nowhere. the router and the computer ar speaking but no matter what i do i cannot connect to the net, i am begining to wonder if the router is suitable for the apple. any suggestions would be very much appreciated. thank you. k rennie
  • enyam Oct 03, 2008
    I can't install my gigaset se587 if i try a manual set up in the address line i get a message that the page cannot be displayed.
  • 6 Answers
HI,
You can try manuall setup of da router.
The Default gateway for Siemens Gigaset SE587 is 192.168.1.1. Open Internet Explorer and put the def gateway in the browser.
The default username and password for siemns router is admin.
Click on Setup Tab than Basic Setup on left hand side. Update the details as folloing-
Use – Tiscali data PPPoA Interface
PVC Selection – Tiscali data PPPoA
Authentication – Auto
User Name - Tiscali u/n
Password - Tiscali password
PPPoA Connection Mode- Always On
NAT - ON
And click on save settings. To confirm if the customer is connected, check the status of Online light – which should be green
. Alternatively click on status (On top) to check internet status to confirm connection.
Setting Up Wireless connection – Click on da wireless tab on the top.
Ensure that the Auto channel is disabled and the wireless channel is 11, wireless n/w is Enabled and mode is Mixed.
To secure the wireless connection – Click on Wireless Security option on left hand side
If you want the Security mode as WPA than select the wireless security mode, as WPA and enter WPA Shared key which would be on the base of the router. Again click on save settings.
Try connecting to the wireless network again and I m sure it should work..... lemme know if it does.
Cheers
SHADAB
Posted on Sep 10, 2008
  • Slabcab Oct 31, 2010
    You guys are brilliant, you save people so much time! Thank you
Let me HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Download mozilla firefox browser and install SE 587 manually / if u r getting stucked any where call ur service provider i,e tiscali.
I can assure u that with this u'll get the best support from TISCALI technical team.
Posted on May 17, 2008
I have se587 and been using it with MACbook. The CD is not useful as it is for PC only.
With mac, connect the mac to the router using the ethernet link. download the fire fox browser from anywhere where you have access to internet. Safari produces errors when trying to set the router.
then type the ip address of the router and log as admin, and the same for password. now set your username and password. save. and that it, done!
Posted on Apr 21, 2008
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
Hello there ive recently been given a fijusti siemens systemax laptop(used) and ive tried to connect it to my wireless router, but it is not working, however it does only work via the yellow data...
If it has inbuilt WiFi, make sure it is switched on and then try connect with your wireless router.
If it does not have a built iWiFi, then try purchase a USB WiFi adapter and make use of this to connect to your wireless router.
Remember to install the software/driver for the USB WiFi adapter
Oct 05, 2017 | AOpen 1557-G (96NDU01G05C) PC Notebook
Pvc selection keeps changing to dial up mode
  • delete the dial up connection on the internet option
  • click tools-internet options on the internet explorer - click connections tab, delete all dial up on the box, and select never dial a connection
Aug 04, 2009 | Siemens SpeedStream 2624 Router...
Linksys WMP45G will not connect to wireless modem
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Jun 09, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
No internet connection with Siemens 587 router / Tiscali
Try this... power down your modem, router, pc and imac, then power up in this exact order, modem first, then router then the computers and see if that works for you...Hope this helps!!
--Joshua79
Apr 06, 2009 | Computers & Internet
Error 51330 on nintendo wii siemens gigaset se587 wlan used.
hi
i have just solved this problem on the SE 587, hope it works for you.
1) in internet explorer type 192.168.1.1, which should bring up your router settings - then select "wireless" and then "basic wireless settings" - under "auto channel" set it to "disable" and the set "wireless channel" to "1" , then "save settings" - my pc briefly went offline and quickly came back.
2) when setting up the connection on the wii you need the code from the bottom of the router - make sure you have "caps lock" ON on the wii when you set up.
3) now everything works perfectly on the wii - you dont even need the pc on! just the router.
good luck, IAN.
Dec 16, 2008 | Siemens (120-5830-001) Modem
Need to reset siemens se 587 router
please verify it's a se 587 because I found no routers with that info...... However this being said to do a 'hard reset' meaning it will reset the router to the factory default... on the back of most routers will be a small little hole the tip of a pen/penicl or paperclip will fit. Press in there and you will push a button and hold for 20 seconds or if possible and you can see the front if you see all the lights flash twice and then power down. This should reset the router
Dec 04, 2008 | Computers & Internet
Im having problems conecting my nintendo wii to my tiscali siemens gigaset se587,can you help me please as i have tried to link them both together with a wireless conection but i just get an error message?...
hi
good luck IAN.
Sep 02, 2008 | Video Game Consoles & Games
Siemens SpeedStream 2624 Router (936-2624-001 kit) Logo
4,168 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
