Question about Olympus FE-170 Digital Camera
Battery type used in fe-170
Type of battery used in fe-170
Classic AA
Posted on Mar 29, 2008
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
Olympus FE170 digital camera shows battery compartment empty with batteries in place I have the same problem. When I place fully recharged batteries in the Olympus FE 170, the camera won't power on at...
on rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Dec 16, 2008 | Olympus FE-170 Digital Camera
FE-170 - Lens extends & retracts 3 times when powered on.
appears to be power issue in the camera but you can try the lithium AA batteries that are located in the photo section of your stores... they are more powerful than regular AA batteries or else send to repair shop
Dec 04, 2008 | Olympus FE-170 Digital Camera
Olympus fe-170 will not switch on!
does appear to be power issue, you can try lithium AA batteries or send to repair shop
Nov 28, 2008 | Olympus FE-170 Digital Camera
No sound recording during video recording with olympus fe 170
To my knowledge, an Olympus FE-170 has no audio recording capability and records the video on 15FPS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Olympus FE-170 Digital Camera
My Olympus fe-170 6.0 megapixel Digital camera
See if you can unscrew the battery door and find out exactly what the problem is.
Use the proper tools - screwdriver etc., etc. Check for any blockages - debris etc., etc. If the door is not broken you may just have to put it back on and tighten the screws that hold it closed.
Oct 09, 2008 | Olympus FE-170 Digital Camera
Olympus FE-170 Digital Camera Problem:
cant you show your the drivers of FE-170 olympus
Jun 16, 2008 | Olympus FE-170 Digital Camera
Broken Lcd panel
Broken LCD screen is quite easy to replace on the FE-170 and FE-210. I have purchased cameras with bad lens but good LCDs on ebay pretty cheaply( compared to having Olympus repair camera).
Mar 01, 2008 | Olympus FE-170 Digital Camera
Red Flash mark while taking photo
It sounds to me like you are not waiting for the camera to charge the flash when turning the camera on or between shots. It seems you are using 1700mAh batteries and most modern digital cameras are better off using 2500mAh batteries. Your camera was released in September 2006 so it is considered "modern". With 1700mAh batteries, your flash (warm-up) recycle time time will be rather long or the amperage may not be enough to fully charge the flash unit. I highly recommend Duracell 2500mAh rechargeable batteries.
Oct 12, 2007 | Olympus FE-170 Digital Camera
Olympus FE-170 Digital Camera Logo
67 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
