Question about SanDisk 2GB microSD Memory Card
Sandisk micro SD
I brought a micro sd and it says when i go 2 copy to it it says the disk is write protected help??
  • 344 Answers
Check the adapters switch is in the unlocked position
Posted on May 04, 2010
How can I transfer 2 gigabyte micro scan disk to a 4 gigabyte micro scan disk?
There are two basic ways to tranfer files from one to another SD.
The first one is if you have a SD reader with two slots. You can then put one SD in a slot and the other in another slot and copy all the files from one to another.
The second option is to pass through a PC. You should copy the content of the first SD to the PC and then connect the second SD and copy all the data on it.
Aug 24, 2011 | SanDisk 2GB microSD Memory Card
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card is locked how to unlock
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
I've Been Syncing Music Onto My Micro SD Flash Reader With No Problem Until Now. It Keep Saying Can't Create or Copy Certain Files Because The Disk Is Write-Protected and Would Like To Know How To Remove...
On the SD Card adapter housing for a Micro SD card, look along the edges and you will find a small tab. This tab slides back and forth to either lock or unlock the card. It is for write protecting you files.
Feb 25, 2011 | Kingston MicroSD 2GB (2 Gigabyte) Card for...
I am unable to copy files to my memory card the system is displaying the error as " disk is write protected "
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 22, 2010 | SanDisk 2GB microSD Memory Card
Disk wright protection
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 17, 2010 | SanDisk 2GB microSD Memory Card
I have a SanDisk UltraII and the card is write protected (not locked). I tried to erase using the disk utility on my MAC but it wont let me. How can I get rid of the write protection? Thanks in advance...
Dec 14, 2010 | SanDisk 2GB microSD Memory Card
How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
Apr 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Write protected
micro sd card have a little switch on the side, move the switch to its other position to enable disk-writing
Jan 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB microSD Memory Card Logo
186 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
