Computer with two hard drives freezes when booting using old XP drive. I have a computer with two separate hard drives. One drive has Windows 7 Home Premium 64-bit installed. The other has Windows XP Home Edition 32-bit. Both drives are connected to SATA ports on the motherboard. When I boot using the Windows 7 drive everything works well. I am also able to access the files on the Windows XP drive from Windows 7. When I boot with the Windows XP drive the computer hangs after loading the desktop and the icons. Some of the drivers are not loading because I am unable to use either the keyboard or the mouse (USB). After a minute I receive a dialog box stating that a CD-ROM drive has not passed Windows Logo Testing. I am not sure how to get the old drive to work.
  • 3 more comments
  • magian_dlc May 05, 2010
    I have already tried booting into Safe Mood with the XP drive. When the mouse cursor appears onscreen It still has the same problem - the mouse along with the keyboard are frozen and I can't do anything.
    I have tried booting onto the XP drive in Safe Mode and I still have the same problem: the mouse and keyboard do not work. Also, I have tried unplugging the power and the SATA cables from both CD drives and I still have the same problem.
    Thanks for the suggestion, but I can't find anything in the BIOS about shadowing or caching.
    I still have the old pc that the hard drive came out of. Maybe I could put it back into the old tower and delete the USB and CD Rom drivers and then put it back into the new computer?
    Help.
    I looked earlier but I was still unclear how to proceed. I believe that I need to boot from a Windows XP install CD and then use F6 to load drivers during setup. Is this correct?
    Sorry for the trouble... I think maybe I am missing where to get started or I am not seeing something.
    President:
  • 3,278 Answers
Hello.
I would recommend removing the drive with Windows 7 and just use the Windows XP drive. Reinstall Windows XP and be certain to have all the hardware drivers available from that system. Once that is completed, then add the other drive.
It sounds like you took a drive from your old system and installed it in the new and now you are trying to get it to work. Even if the brand is the same, many of the hardware components could be upgraded or changed and would need different hardware drivers.
Hope this helps.
Posted on May 05, 2010
  • NinaE May 05, 2010
    Best way to do this, if possible, is to have another computer available and connected to the Internet. Boot with the Windows CD, install Windows and see how far you can get. If the system boots, go to Device Manager and see which items have a ? or ! next to them and determine which drivers you need. Download those drivers from the other system, connected to the Internet. It does get pretty messy if you can't find or determine which drivers you need.
  • 493 Answers
You can enter BIOS by pressing the F2 key after the initial black screen lists your hard drive(s) and CD-ROMs and before Windows begins to load. (Note: If you are not familiar to BIOS ask to your friend to do this) It's not recommended that you change your BIOS settings unless you really know what you do.
If F2 works, look for where you might disable caching and shadowing.
(The key F2 for entering BIOS may be different for your PC)
After rebooting you may pass the blue screen then enter XP.
Right-click on My Computer, select Properties.
Go to the Advanced tab and click the Startup and Recovery button.
Uncheck "Automatically Reboot" under the System Failure
section.
Install the right CD driver if you can find for your CD/DVD Drive compatible for your MS XP operating system.
Hope this works.
If not check this web site.
Good luck.
  • 2 more comments
  • Ibrahim OKTAY
    Ibrahim OKTAY May 05, 2010
    Hi again,
    To set the command "DriverSigningPolicy = Ignore" in the "unattended.txt" file may help you.
    Would you please try to do that. To do that follow the instructions written in this link. I think that may help you, and solve your problem simply.
    Best
    ioktay
  • Ibrahim OKTAY
    Please do followings.
    The Windows XP Setup Manager Wizard is not installed by default. To install and use the Setup Manager Wizard:
    1. Open the Support\Tools folder on the Windows XP CD-ROM.
    2. Create a new folder on your local hard disk C which you want to install XP operating system.
    3. Copy the Deploy.cab file to your new folder (example: C:\ setmng\ )
    4. Extract the Deploy.cab file in this new folder.
    5. Find the Setupmgr.exe file. Double click on it. The Windows Setup Manager Wizard starts. Follow the instructions in the wizard to create an answer file.
    In that answer file (unattend.txt file) Set DriverSigningPolicy to ignore .
    (This entry causes unsigned installs to silently succeed and your CD drive will work).
    Then restart your computer.
    Please see the pictures below which explains the procedure at the beginning of Setup Manager.
    Hope this helps.
    Hope this helps
    ioktay
  • Ibrahim OKTAY
    Please do the same selections in the pics to create an unattend.txt file and to be able to modify the
    file. (such as the operating system selections may be as yours) You will need the XP CD key.
    In that file you need to set the Set DriverSigningPolicy to ignore (in Unattend.txt)
  • Ibrahim OKTAY
    After setup completed and if you can't manage to set the DriverSigningPolicy to ignore you can do it after setup processing manually as below:
    1. Use Notepad to open the Unattend.txt file that you created.
    2. Find the DriverSigningPolicy and set to ignore
    3. If can't find there; on a new, blank line under the [Unattended] section, type the following line:
    DriverSigningPolicy=ignore
    4. On the File menu, click Save.
    5. Quit Notepad.
  • 4,281 Answers
This happen when driver is incompatible with windows.
Also make sure when you boot computer with old harddrive it is set as master .
You can set it with jumper it is in back side of harddrive.
Then if it is already as master then start computer in safe mode for that when you boot computer with old harddrive press F8 key then enter ion safe mode then go to device manager right click on my computer icon click on property then hardware->device manager.
Then uninstall cd rom driver and usb drivers
Then press windows key +R then you can see run type in run "chkdsk /r" then press ok then press "y" then restart computer then it fix and recover error on harddrive.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
  • If you want o repair winxp you need windows xp disk.
    Insert that windows xp disk into cd/dvd rom then when you power up the computer press F1 or F2 or del or ALT+f2 to enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
    Then it boot with that disk.
    Then press any key to boot from disk then follow thje procedure on screen and enter ion recovewry console then type in prompt "chkdsk /r" then pres enter then it fix and recovers error on hardrive.
    Then restart computer and again boot with disk this tie choose R for repair previous windows then it repair it.
Hard drive from my xp computer, added as external hdd to new windows 7 pc, need to get ' permission
umm xp used a completely different kind of hard drive and may not be compatible with the windows 7 environment I gather you might be trying to import the old data from that xp drive and use it on the new machine, correct? what is model number of new computer if this in fact is the case.
May 23, 2012 | HP Omni Computers & Internet
Sir, i am using windows 7 ultimate. i would like to install another one operating system (i.e) windows xp professional. now i insert the win xp professional disk into it but the install windows xp is...
boot your computer with windows XP cd. it will install winXP automatically but remember to install windows XP other than the drive where your win7 is. for examp: if your win7 is in C drive, install XP in D drive. hope you can do.
Aug 29, 2011 | Computers & Internet
I have want to setup Windows xp and windows 7 together .Meaning when start up computer have : Windows xp Windows 7 I try to setup two windows ,but i setup windows xp lost windows 7 and setup windows 7...
Not sure what you have done so far. You need to divide your hard drive into two sections. Install XP first on to one section. Then use a program to manage your computer start up, the one I use is called Easy BCD this is a free program and works great. Once you cut your hard drive and install XP make a copy of your start up partition. Install the Easy BCD program and make a back up again. Then Install Win 7. Then on the Win7 side install the Easy BDC program and set up the menu choices. I run a 3 way boot with XP and Ubuntu. Hope this helps Fix Ya up.
Jul 09, 2011 | Computers & Internet
I just upgrade to Win 7. Now everytime when powering up the machine, there are two boot options like this: Previous Windows Operation System Windows 7 (with Windows 7 highlighted) Of course I...
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer.
When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
-G33k
Jun 11, 2011 | Microsoft Windows 7 Ultimate for PC
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
I have a windows 7 ultimate, but i want to change it to windows xp service pack 2. can i change windows 7 to win xp without damaging all the data i have stored?
YES BUT FIRST YOU HAVE TO WIPE THE HARD DRIVE. YOU CANNOT "DOWNGRADE" FROM 7 TO XP...ONLY UPGRADE.
BACK UP ALL DATA FIRST
Oct 15, 2010 | Microsoft Computers & Internet
How to set up dual boot for two hard drives?
My freind, you can boot from two hdd inside the same computer. You can only boot from the primary HDD. What you need to do is install both Windows 7 and XP on the primary hdd in different partitions. Then when you boot the system it will give you the option for booting to both XP and 7. You dont even need the secondary hdd unless you are looking to have more storage space.
May 04, 2010 | Computers & Internet
Computer crashed. Computer specialist restored drive. now cannot boot windows. Used restore disk. Did not work. computer boots dos screen then shuts down. boots again then shuts down.
Sounds like a Windows issue. Depending on how valuable it is to you to get your data off the drive, I would suggest buying a new hard drive (they are fairly cheap these days), installing Windows on that. Word of advice: Remove your old drive when doing the Windows install, so as not to accidentally select the hard drive your data is on. Once you have Windows installed, shut down your computer, remove the power cord, and install your old drive on a separate IDE channel or SATA connection. If your PC still tries to boot to the old drive, change the boot order in your PC's BIOS.
Aug 10, 2009 | E-Machines eMachines Desktop PC
Two hard drives Vista and XP not booting
If you would like to start up in the xp ,At computer start up hit F1 or F2 there are so many ways some times its hold the del key ,once your into the BIOS you can change the boot order of your drives to make the drive xp is on load first .You will have to do this everytime or buy a program that will do it for you .I would just leave the power unpluged on one of the drives until you need it that way it will be safe from a virus or if you have a hard drive crash you always have one good drive .Hops this helps.
Dec 19, 2008 | Microsoft Windows Vista Home Premium with...
Multibooting
nope not if its in vista u would nee dto dual boot dl alll latest drivers software for vista then mosttime it works on older stuff
Oct 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
