Question about LG LS-K2430HL Heat Cool Mini Split Air Conditioner
5mint cooling 5minuts heating
My lg split aircondition 24000btu its working 5minutes cold and 5 minutes heat, what is the problem.
    Problem Solver:
  • 11 Answers
The reverse valve and silenoied are bad, you need to change them or replace the condencer.
Posted on May 21, 2010
I have a Bonaire split aircondition & heating system. When I use remote controll change mode doesn't work heating mode. Other mode are working properly but heating mode doesn't work.
check the ambient temperature as there is most probably a lock out feature that will not allow reverse cycle to work if the system cannot remove the cold from the evaporator
To understand the system , when in cool mode the outside unit is called the condenser and in effect removes the heat trapped by the evaporating gas in the evaporator to the atmosphere
in the heating mode the roles of the evaporator and the condenser are reversed so that the evaporation of the gas in the now evaporator out side is now compressed in the inside unit and the heat from that compression action is released into the room
read the manual for the unit or talk to an ac specialist and have it explained
Apr 18, 2015 | Heating & Cooling
How to heating. it's always cooling
Keep heat mode and temp setting+5 degree than your room temp.Still no heat check power to heating element. No power replace heating temp senor. If it's with RV, check power to RV and also warm in suction pipe(higher size pipeline near compressor).
Jan 27, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 16, 2009 | Fujitsu 24R1 Air Conditioner
AIR CONDITIONER LG S18AN
The operating LED will be blinking 5 times, means that there is a
comunication error (serial comunication) between the outdoor and the indoor unit.
Dec 28, 2008 | LG LS-K1830CL Cool Mini Split Air...
Error Ch 26
1.check indoor unit wiring.
2 check cirkit board
3 check selector switch
Mar 25, 2008 | LG LSC183VMA Split System Air Conditioner
AC Compressor
Does not sound right to me.My guess after doing what every he was doing he probably installed a start capacitor or repaired a burnt wrie, got the compressor running and charged for a lot of guess work. Just guessing.
Jan 04, 2008 | LG Heat cool Window Air Conditioner
LG LS-K2430HL Heat Cool Mini Split Air Conditioner Logo
143 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
