Question about Hotpoint RGB745 Gas Kitchen Range
Oven will come up to preheat,but will not maintain temp. the ignitor will come back on but burner will not light again.
  • Hotpoint Master
  • 43,501 Answers
If your electricoven will come up to preheat,but will not maintain - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 17, 2011 | Ovens
The oven seldom lights. Igniter is working, there's usually no smell of gas, burners and broiler are working properly, replaced dual gas safety valve with no help. When it does light, it won't maintain...
Just because it glows that does not mean it is not bad...
heatman101
Sep 07, 2010 | Maytag Kitchen Ranges
After the oven preheats the I can hear the clicking, but the oven will not relite therefore the temp just drops. If I shut off the stove and put the temp I want back in the stove will lite, but again after...
there is a problem w/the burner....kitchenaide is aware of these issues and the new burner should come with a new ignitor already attached to it,poor design...
Mar 06, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
GE Range...oven problem. Oven turns on but doesn't preheat to set temp. The broiler burner works fine.
Check resistance of lower burner ignitor. Should be above 4ohms. If not, replace. Part 40-75$ + labor. Let me know if info helps- ED
Mar 02, 2010 | GE Ovens
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Nov 10, 2008 | Kitchen Ranges
Low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Oct 17, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag gas kitchen range/oven model# MGR575 ADW during preheat cycle in oven seems to keep trying to start left bank of burners over and over again. Gas can be heard flowing an ignition occurs and then...
that actually sounds to be pretty normal operating procedure unless im not understanding correctly, the unit will shout off, and cycle back on to maintain proper temp as cooks, the" top lef bank of burners" they show signs of clicking??? but not actually igniting correct??? and do they ever start to click when unit is completly off???
Apr 07, 2008 | Kitchen Ranges
Hotpoint RGB745 Gas Kitchen Range Logo
287 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
