Question about Kitchen Ranges
My stove does not maintain a consistent
I have a kitchenaid superba stove that does not maintain a consistent temperature in the oven. Sometimes it is off by 25 or more degrees but I can't adjust for that because it isn't consistently off by the same amount. I have used two thermometers at a time to make sure it wasn't the thermometer that was off. My baking is really suffering and I have no manual as the stove was here when I moved in. Any suggestions?? thanks
  • Kitchen Ranges Master
  • 43,501 Answers
This is most common with electric ovens and the bottom element goning bad...but I will also include the most common problem for gas ovens also when this happens, as you did not specify which you have...
If your electricmy stove does not maintain a consistent - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
If you have a gas oven...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 06, 2010
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
How to unlock the door on kitchenaid superba stove thank you
http://www.manualslib.com/manual/87576/Kitchenaid-Kbhs109.html#product-SUPERBA KEMS308
Jul 21, 2015 | KitchenAid Ovens
I didn't use the stove at all the day before i woke up the next day and the stove has a code on it F4E1 what does this mean and how do i fix it my stove is a kitchenaid superba glass top
Short circuit detected; oven temperature sensor. Check sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check wires between electronic range control (also called clock or ERC) and sensor.
VOTE FOR ME IF THIS HELPED.
LEO PONDER
IMUFO2
Replace sensor if other components check normal. Replace electronic range control (also called clock or ERC) if fail code reoccurs
Jul 29, 2011 | Kitchen Ranges
KitchenAid Superba Gas Range error code F3 E0 when trying to strat the range
The F3 E0 means
Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse Good luck
Nov 27, 2010 | KitchenAid Kitchen Ranges
The oven will not reach desired temperature. Had
it sounds like you have a bad temperature controller thermostat or your temperature sensor inside the oven, (a metal rod attached to a thin metal wire) is not in its proper place. It clips into connectors located at the back center of the oven itself.
Mar 14, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Kitchenaid superba stove
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Kitchen Ranges Logo
263 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
