Question about Zanussi F1245W Front Load Washer
Zanussi fs 1555 w machine stopped during cycle now drum will not turn
  • 269 Answers
If you cannot turn the machine by hand then it may be an idea to see if the drive belt has snagged around the back end some how take a peep with a torch thru. top.if the belt looks ok it may be that something has got stuck inside the drum.Sometimes socks get stuck between the front of the drum casing and the drum shine a torch around the front by the door seal and see if you can see any objects jutting out if you can be careful and try with a vice grips to pull out if no joy it sounds as if it will have to be a tub out job.Sometimes objects like coins can be fished out thru the back where the heater sits but still a lot of work to get down there.Body of machine has to be split for access.
Good luck
Posted on May 05, 2010
My machine beeps when i try to start it
How many beeps does it make?
Is there a sequence/pause before it repeats?
Sep 02, 2014 | Zanussi Washing Machines
Often while washing with my ZWD14581W, the wash cycle will just stop half way through. There is no error code or any indication that there is a problem, except that the drum stops turning and the remaining...
During the wash cycle that is selected there is a need for the progam to advance further only after it receives information from the next step due to it. so this could be that the dispenser is not working, or the heater is not working or the drum drive is faulting on heat build up.
Check on any of this to confirm or else the main controller board needs a change.
Aug 21, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine will not start cycle.
check water level device,must have in manual,or water pump filter.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi FS 1355 w Drum not turning
DEFF BRUSHES.JUST HAVE SAME PROBLEM MYSELF NOW AND TOUCHED BRUSH HOLDER SLIGHTLY AND RESTARTED..
Jan 01, 2009 | Zanussi FS1455W Front Load Washer
Noisy during some parts of the cycle
it could be the concrete ring situated at the front of the machine. i had the same problem with mine 2 years ago.
Jul 29, 2008 | Zanussi FJD1266W Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi fj1254w washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 04, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi aquacycle 1200
May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
Slim Jim
Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi F1245W Front Load Washer Logo
199 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
