Question about HP Officejet 5610 All-In-One InkJet Printer
Is there a users guide for hp officejet 6500?
I would like to use my hp officejet 6500 all in one printer and scan with fax but having a problem with connection. i need to know if i need a modern or a USB cable connection or wirless connection
Posted on Apr 02, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Posted on Feb 28, 2013
  • 820 Answers
All support for the Officejet 6500, is on next page:
http://www.shopping.hp.com/product/printer/all-in-one/1/storefronts/CB815A%2523B1H;HHOJSID=3GWwLgnP5q4mQGLvtnV1T12FxGgRTJHrLzsZ1P5y17fVkdzQPng4!1105332277
note:
There are 3 types of 6500 Officejet AIO printers, see next overview:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=officejet6500
For a manual for the Officejet 6500 in pdf format (readable with Adobe Reader), select:
http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
Posted on May 04, 2010
  • YourZEN
    YourZEN May 04, 2010
    note:
    The first link I mentioned is not the "All support page". Support shows up, when choosing one out of 3 types of printers.
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
SOURCE: HP Officejet 6500 No scan Options
I am trying to scan, but when I press the scan button it states "No scan options. Refer to device doc to troubleshoot". However, I can't find my device doc. I am assuming there is an easy fix?
Posted on Dec 19, 2009
Mhinhi
  • 10 Answers
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Posted on Mar 01, 2010
  • 145 Answers
SOURCE: HP Officejet 6500 E709 (new printer) will not
Hi ladarlak
There is no full feature driver for Windows 7 yet. Meanwhile HP have printed a workaround at http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01796879&lc=en&dlc=en&cc=us&lang=en&product=90764
Posted on May 09, 2010
  • 5 Answers
SOURCE: Cannot coonect SCANNER (HP Officejet 6500 wireless) to my Windows
I have seen alot of problem/posts concerning HP AIO's and software issues. Typically some of the functions won't work or not recognized by solution center. Try a complete uninstall of all associated printer software, run registry cleaner if you have it, restart, then try completely uninstalling your Antivirus/firewall software. I have seen that just disabling Antivirus/firewall still causes faulty installations. Now, reinstall your printer software/drivers and connect cables only when told to do so. Some reason the AV/FW software blocks some of the AIO's apps from completely installing.
Hope this works...Good Luck!
Posted on Jun 12, 2010
Need Manual for HP Officejet 6500A Plus
You may download the Getting Started Guide and the User Guide from here.
Jul 21, 2012 | HP Officejet 6500 Wireless All-in-One...
Ineed a users manual for my HP Officejet 6500 Plus printer
Access the manufacturer's web-site: http://support.hp.com
Enter '6500' and do the search.
Select "Downloads".
Select "Documentation".
Download the User Guide manual, as a PDF file.
Apr 10, 2011 | HP Office Equipment & Supplies
How get faxed confirmation HP officejet 6500
You can enable fax confirmation before sending a fax by selecting Send & Receive
Press SETUP on the control panel
Press PRINT REPORT, then FAX CONFIRMATION
Press right arrow to select SEND & RECEIVE
Press OK
Additional instructions from HP Support User Guide
Click on link and select FAX
Feb 19, 2011 | HP Officejet 6500 Wireless All-in-One...
How to copy
http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf......check this link, this is the user guide/manual of HP Officejet 6500 all in one ink jet printer...
Nov 10, 2010 | HP Officejet 6500 Wireless All-in-One...
Need manual for hp officejet 6500 0709a
Hi
1. Please click on the following link and one it opens up the complete page
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3795314&lc=en&cc=us&dlc=en&lang=en&cc=us
2. Click on User guide, It would take sometime to open up the complete document
3. Once the complete document is loaded, click on the save option to save it on the computer
Note: You would need adobe reader in order to open this file and if you don't have that then please go to the following link to download it
http://get.adobe.com/flashplayer/
All the best!!
Regards
Oct 30, 2010 | HP Officejet 6500 Wireless All-in-One...
Trying to get a manual for my new officejet6500
this should be a direct like to all the manuals available on the HP site for that All-in-1 printer http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=uk&product=3795314&lang=en&
this should lnk directly to the PDF - user guide
Mar 21, 2010 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 5610 All-In-One InkJet Printer Logo
483 people viewed this question
Seeker5211
Seeker5211
