  • 4,234 Answers
Anyone that can work with surface mounted components can fix this. When I get these, I usually charge $80 for the labor. The entire laptop must be dis-assembled to get at the bord for correct replacement.
Posted on Mar 26, 2008
Why won't my daughters acer chromebook charge?
You need to verify if the Charger is Working if it is
you need to verify if the battery is well inserted in the laptop
if this OK then try connect the charger to the laptop
open the laptop and while it is on remove and reinsert the battery
Jun 30, 2014 | Computers & Internet
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
My Acer Aspire won't recognize the battery charger. I plug it in and nothing happens. After I unplug and re-plug it back in several times, sometimes my computer will recognize it and will start to...
Try wiggling the plug around a bit to see if you can get contact. You could also try borrowing a power supply if you know someone with the same machine to isolate the problem.
Oct 16, 2013 | Lifetime Acer Aspire 4810TZ-4011...
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Battery charging
Check your charger to make sure it is the right one for your laptop. If it is then test it's output to make sure it is producing the correct voltage and amperage. You can read the label on the charger to find out what it should be. Then a simple test with a multimeter will tell you what you want to know. If that is all good, check the contacts where the battery plugs in. Are they in good shape? Not bent or broken. Clean them with a pencil eraser so they are shiny. Now, disconnect the charger and plug in your battery. Do you have an indicator of power? Will your laptop boot? If not, use the multimeter to test the output of the battery. It should read the same output voltage as the charger.
Jun 04, 2012 | Toshiba Satellite A665-S6086 Laptop
No power on hpdv1000
You could have a broken power socket where the charger plugs in to the laptop. If the battery is flat and the socket is broken or loose then it wont charge and will be completely dead. If the socket is ok then it should power up with just the charger plugged in, even without the battery plugged in. You could also have a broken wire in the plug on the charger, the end that plugs in to the laptop.
Feb 01, 2012 | HP Pavilion dv1000 Notebook
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
Laptop won't charge
You might need a new could try removing the battery, plug laptop into ac and restarting. Or you might need a new DC power jack. If you wiggle the cord where it plugs into the laptop, and it starts to charge normally, then the DC power jack needs replacing.
Apr 26, 2010 | Sony VAIO Notebook
I am not getting any power to my laptop.
1. Laptop may be broken
Connector where power supply plugs in
2. Charger or cable may be broken (especially connector where it plugs into laptop)
3. Battery may be damaged (and may have damaged charger as well)
More details would be nice. :)
Dec 23, 2009 | HP Pavilion dv4000 Notebook
Acer 4620z
Hi sir,
You can get the power pin unit replace on any authorized ACER center.
Also, you can have the external Battery charger as well, just browse through your local ecommerce laptop parts sites.
Hope this helps.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
