Question about HP LaserJet 3055 All-In-One Printer
USB PORTS We installed the 3055 All-In-One, which works fine; but, now none of the USB ports work. Can you help?
  • pjh55 Mar 28, 2008
    Thank you for your advise. Unfortunately it did not work. Our IT dept solved the problem by upgrading the Bios on the machine.
    Again, thank you.
    Again, thank you.
  • 3,037 Answers
Un-install the printer software using Control Panel / Add/Remove HP Printer... Turn off the printer. Unplug it from the AC power. Turn off computer. Next, I plugged the USB cable into computer port and into printer. Plug printer into AC outlet. Start up computer. Let PnP find printer. When asked, insert software CD and follow on-screen instructions. Turn on printer. Hope it works for you too.
>>You might go to Control Panel / System / Device Manager and check to be sure you do not have any conflict alert with the USB port.
Posted on Mar 27, 2008
  • Benjamin Patri
    Benjamin Patri Mar 27, 2008
    Let me know if this works or whether you have any other questions or find anything else you would like us to know about. Thanks and have a Good Day
  • Benjamin Patri
    Benjamin Patri Mar 29, 2008
    The bios huh? I'm glad you were able to fix it, please don't forget to rate this solution
  • HP Master
  • 19,396 Answers
Yes, disconnect power cord from computer and printer for ten minutes then connect it back
  • Ginko
    Ginko Mar 27, 2008
    This hard reset will get rid of electrostatic problems on your USBs, if it does not work you will need to disconnect printer from usb, reinstall drivers from diskette or factory website, then connect printer back.
    Here is support and drivers page from HP: HP LaserJet 3055 All-in-One, it is not opening at the moment, they may have some trouble with website.
    regards
The USB port on the printer is loose and therefore not communicating with my computer.
You can open up the printer and try to fix it, but in fact you will probably need a new part which will have to be soldered in.
An easier solution would be to use the parallel port connection, if there is one. Newer printers don't always have them, and I don't think the 3055 has one.
On the other hand, newer printers often have an ethernet connection, and you should be able to use this instead of the USB. I'm pretty sure the HP 3055 has an ethnet port. You'll need an RJ45 wire. You can get a USB to RJ45 adapter if you need to plug the other end of the cable into your PC's USB port (e.g. if your PC has only one ethernet port and you're already using it for broadband).
Hope that helps a bit. Good luck!
Oct 09, 2010 | HP LaserJet 3055 All-In-One Printer
None of 2 usb ports work, drivers fine in device manager tried uninstall ane restart, drivers all install no issue ,, usb still not working
measure the voltage of the usb ports. if it is higher than 5v, than you have a problem. in this case you have to buy a usb hub and connect it through the pcm cia port.
but for your safety reinstall your os first and see if this happeneds again
Jan 27, 2010 | Dell Latitude D600 Notebook
Tried to connect my usb card from my phone for pics. Suddenly, none of my usb ports are working at all. I am on another computer and my mouse and keyboard work just fine. It IS my usb ports. what could the...
It may be disable your USB in BIOS you should check the BIOS & enable USB in BIOS otherwise USB driver not installed on your system if driver issue insert the your Motherboard driver cd install the all driver.
I hope that this has been very helpful for you
Nov 16, 2009 | Computers & Internet
My usb ports on the back of my motherboard dont work
Check that the USB and LAN functions are enabled in the board's BIOS setting. If everything is set properly and they still don't work, you could have a bad motherboard. Check into the warranty if the board is new enough, or just use expansion cards to replace the lost functions.
Jan 27, 2009 | EliteGroup PM800M2 Motherboard
My HP Laser jet 3055 has worked fine for a long time but now when I press "scan to" an error message pops up on the printer/scanner "not set up on pc". Nothing has changed and the...
Have you plugged in your printer into a different USB port on the computer? If so, return the USB cable to the original USB port it was in before. If not, try another USB port on the pc and have the driver disk handy because it might act like you have never had the printer plugged into the PC before.
Good luck
Nov 10, 2008 | HP Office Equipment & Supplies
Firmware upgrade LJ 3055
I foud the solution read carrefuly and he will works !!!
Turn off the printer .
Open the side cover where place the formatter on the right face
Here you will se a jumper
On your computer delete all hp software
Install HP 3055 pcl 6 drivers and select manualy your usb port where is connect the printer ( the printer is always off)
Download this :
ftp://ftp.hp.com/pub/softlib/software8/COL13630/ma-38209-5/3052-55_FW_Update-20070331.exe
Open the program select your printer and send the firmware (the printer is always off)
When the firmware is upload completly and you see the smileys on the sofrware update.
Closed the jumper P19L on the formatter and turn on the printer.
You will see message on the printer Downloading.
Open immediatly the jumper connection
Wait and you will see a message like Update successfully :)
turn off the printer
wait 5 seconds
Turn on the printer
It s ok
Marc
May 06, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
Scan To Button is not working over Network PCs
I uninstalled the Norton Antivirus from my PC. Now it is working fine.
Jan 13, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
157 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
