Question about Toshiko Original Zoom Trimmer Beard Trimmer
Original Zoom Trimmer Original
How do I change the blade on the trimmer
Qualcast GGT350A1
Hi. It all depends on the Lawn trimmer. What brand is it? You can go back where you purchased the Lawn trimmer and ask them for an attachment blade to use for trimming hedges (did you mean hedges as in edges?). If they have blades specifically for your trimmer then you can do best if you have it attached to the trimmer by them experts. Otherwise if you do it yourself and it's not attached to the trimmer properly, and it comes off while spinning at high speed, you'd better run for your dear life, man! Hedge blades, like the one I have on my trimmer, are subjected to strenuous work and can come lose if not attached properly. The main part is that you treat hedge blades with care when doing the changes yourself. I am not saying that the blade which is similar to a saw blade, could come lose and separate itself from the shaft and fly towards you, but it's better to be safe than sorry. Poorly attached blades do come lose and fly like a flying saucer spinning and whirling in all direction like a yo-yo. Cheers
Michael
Jun 16, 2014 | Garden
How to stop trimmer line spool from spinning off
I bought a Shakespeare Push-n-Load 3 blade trimmer head at The Home Depot for about 26 dollars and picked up a pack of 12 replacement blades for another 7. Did a whole 3 acres worth of weed whacking and still didn't need to change the blades. I was also powering through some pretty thick bushes with ease. Highly recommended.
Apr 13, 2013 | Craftsman 25cc Gas Line Trimmer
After several months without use I have just put in batteries and it does not work
put that battery in some other mobile n check whether its working or not . if rust comes change ur battery
Mar 12, 2010 | Toshiko Original Zoom Trimmer Beard...
Trimmer not working
the trimmer may be jammed with hair particles. clean the trimmer blades really good with an old toothbrush dipped in rubbing alcohol. you can also turn it on with the tip of the trimmer blade dipped in a shallow container of alcohol.
if your trimmer blade is sufficiently clean and still doesnt work, the rocker arm that moves the blade must be broken. Remington does not offer replacements for the trimmer part
Jan 16, 2010 | Remington Microflex R-842 Electric Shaver
How to change blades
Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
Mar 16, 2009 | Husqvarna Garden
HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
Andis Outliner II Trimmers
look if the trimmer is pulling hair, its not lack of oil
its maybe the speed of the trimmer needs to be faster.
its the the plastic flat head skrew on the side.check if the blades separate easiley if theyt do sometimes that makes the trimmer pull hair to.there might be a little plate on the inside of the trimmer and its not holding the blades tight.adjust that not to tight though then the trimmer wont cut
Dec 06, 2007 | Andis Outliner II Hair Trimmer
Toshiko Original Zoom Trimmer Beard Trimmer Logo
936 people viewed this question
Top Toshiko Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Toshiko Health and Beauty Expert? Answer questions, earn points and help others
