Question about Philips DVD622 DVD Player
No video in my philips dvd622
Sir,
I have checked it is not in progressive mode and i have connected to composite video input to the tv
    Champion:
  • 220 Answers
Try connecting to S-video or DVdcomponent.If you have only composite video input for TV,Connect to video cable to Yout in DVd,If you get a Black and white picture,Your Dvd video card is defective.
Maybe not cost effective replacing it.Contact local Philips service center.
Samir
Posted on Mar 27, 2008
How best connect external DVD to TV: Composite or Component? Both available on both units
If the TV does have a component input, that will be your best choice. Component video provides an HD signal; composite is only an SD (480i) signal. However, if the TV doesn't have 3 RCA ports (red, green and blue) for the video itself, in addition to the red/white RCA audio ports, you may be missing an adapter that allows the port to be used properly. You'll need to set the TV to the external video input with a Source or Input button on the TV or the remote. If you press the DVD button on the remote, the TV will only attempt to get the signal from the internal DVD.
Please add a comment with the make and model of your TV for additional information. A number of TVs (like some LG models) share the composite and component inputs and use an adapter to reduce the input to a smaller area on the TV. Without the adapter, the TV can't correctly identify the signal. The component video adapter for my LG TV looks like this: http://www.amazon.com/LG-OEM-Original-Part-EAD61273107/dp/B00C5HXILE . There's a second one for the audio signal.)
I hope this helps.
Jan 06, 2016 | Philips Televison & Video
How to connect a dvd player to lcd tv
Your DVD player's output is Composite Video (the yellow connector) plus stereo audio (the red and white connectors, for right and left audio)
The inputs on your TV are for Component Video, which splits the video signal into three cables (Y for brightness, Pb and Pr for blue and red, respectively)
Check your TV to see if it has a composite input (single yellow connector, labeled "video" or "composite")
And be sure to let me know if this helps!
Oct 24, 2009 | Televison & Video
Panasonic DMR-HS2 RF out is not outputting signal CH3 CH4 off
The most likely cause of this is the unit being in progressive scan mode. In progressive mode, the composite output is disabled. If you can, connect the DVD using the component output connections. If your TV does not have component input, connect the green connector to the yellow on the TV. If the unit is in porgressive scan, you will see a garbled picture on the screen. The only way to fix this is to turn off progressive scan. The manual will tell you how to do this.
Dan
Apr 10, 2009 | Sony STR-DG510 Receiver
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Input/output drama
hello sir,,
Are u sure the red blue green chord signal is connected properly to the source of the signal?
thank u
Jul 12, 2008 | Philips DVP3140
Check if you have not accidentlychanged to progressive mode which can cause this proble.
Are you connected to TV using Composite video out?Try connecting using S-Video or DVd (component inputs).
Do provide feedback and rate this solution.
Samir
Mar 26, 2008 | Philips DVD622 DVD Player
Philips DVD622
reset 1.hit the menu button on the remote play with the options there you will find it its a common task on these dvds!
to go region free
1.open it
2. hit 2812
3.press ok until you get 9
4. shutt off then reopen it
it should be region free i am not shure if it needs to be repeated!
Jan 09, 2008 | Philips DVD622 DVD Player
Tv connection
connect the composite video output of the player to the composite video input of your TV. The jack should be marked in yellow. Then connect your Audio input of the tv to the Audio out of the player.
Oct 09, 2007 | Philips PET710 Portable DVD Player
Component Input
To save cost on this model, as with many others they are sharing the S-Video input circuits with the composite input circuits at the entry point. There is a kill switch incorporated with the S-Video jack in the set. Even if you put an external switch box to the set, the composite video will not work unless the S-Video plug is pulled. Your best solution is to get a TV set with a true multiple video input. The other alternative is to have a sat receiver with an external input for throughput feeding. Another alternative, but not as good quality as S-Video, is to use your sat receiver in the composite mode to the set, and have an external switch box to select one or the other.
Sep 17, 2005 | Panasonic CT-27SC13 27" TV
Philips DVD622 DVD Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
