Question about GE Spacemaker JVM1640SJ Microwave Oven
Surface lightbulbs changed but now can't turn off lights.
Both of my surface light bulbs burned out. I bought the exact same bulbs and changed them. As soon as I put one of them in the light came on same as the other. I put the cover back over the bulbs and tried to change the brightness to night light and that didn't work, neither did going to regular surface light. Now I can't even turn off the bulbs at all. I'm a little baffled on what to do. Can someone help if possible. Thanks so much.
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or two.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: surface light "nightlight" will not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Posted on Feb 17, 2009
Where to get light for ge profile microwave
It should be listed here:
https://www.geapplianceparts.com/store/parts/category/lightbulbs
With more information about the microwave, a Google search could find the exact bulb, and its price/availability.
Jan 15, 2018 | GE Microwave Ovens
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
How do you repair the surface light on microwave
You know how when you turn on a regular light bulb and it burns out with a bright flash? What happens is that when the filament burns out, it breaks and bounces back and hits the other electrical post and basically shorts out causing that bright flash. Sometimes, when the light bulb in the microwave burned out, it shorted out, and caused the circuit-board trace to burn up. (This is not just conjecture; I've seen it.) If that's the case, then you would have to replace the main control circuit board. Unfortunately, a rather expensive repair for no lights. (Although the circuit board trace can usually be repaired by direct-soldering a wire to replace the burned trace. Sears repairmen won't do this, but an independent electronic technician could do it.
Apr 23, 2014 | Kenmore 62622 Microwave Oven
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
JVM1460 surface light problem
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Microwave
Absolutely. That's why they make shop bulbs to use in one's portable garage work light and garage door opener.
Slamming the door of a microwave is never good idea!
Another factor is touching the new bulb with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
344 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
