Question about Maytag Washing Machines
Won't drain just before spin cycle and overflows when rinse kicks in
  • 1 more comment
  • nijenhuis May 04, 2010
    makes sense, and I suspected that at first, but why would the water level switch function work and shut the water off when the tub is filling the first time to wash, then not draining before the rinse. If I manually turn the dial to spin, the machine drains no problem and then spins. If I mss that, it will overfill in the rinse cycle and flood through the back and then can't spin because it's full of water. The only step it's not doing is not draining after the washing (usually spins a little at that point right?) and just before the rinse.
  • nijenhuis May 05, 2010
    Maytag Performance model # PAV 1200 AWW
  • nijenhuis May 06, 2010
    I will try this. Thank you!
  • 218 Answers
Note sure how old of a machine this is. I am assuming that this is a Maytag.
Things to check,
1.Underneath machine check belt or belts(2 belts on older style)
2. Check drain hose for obstructions.
3. open cabinet and check for blockage in the pump and hoses.(old style opens with 2 screws at the bottom front)(newer style top there are 2 clips left and right of front panel about 2" in from the corners push in on clip with butter knife or other thin bladed object and pull up on top at the same time.
If this is not a Maytag or you need further assistance please let me know.
Posted on May 06, 2010
  • Maytag Master
  • 8,220 Answers
This is a simple design. The motor goes in one direction for wash and that keeps the water in the tub. To remove the wash water and prepare for rinse the timer reverses the motor making it turn in the opposite direction. This does 2 things, pumps out the water and spins the basket. So what can go wrong? Bad lid switch,bad pump, Bad Thrust washer, or bad timer. As far as water going in the tub that is a weird one, coulld it be the water level pressure switch tubing has vibrated off? I have seen that. This whole problem might simply be a worn out belt. I have a wonderful link to a pictoral which shows how to replace the thrust kit:
Thrust kit replacement 101
To obtain a copy of service literature for you washer CLICK HERE
Posted on May 05, 2010
    President:
  • 1,554 Answers
Please indicate the exact model number of the washer for specific and accurate troubleshooting advice.
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link to get the probable cause of why the machine is not draining…most probably a clogged drain hose stops machine to drain...
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itwontdrain
As far as the over flowing is concerned the water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Posted on May 04, 2010
Frigidarie Stackable Washer and Dryer leak
Check the Drain Tube, Check the Screen. When it gets to the FIRST Spin Cycle, Check the Water Level inside the Drum and see if it is Completely Draining... There is a Water Level Switch that should not be allowing it to Overflow so you may have an issue there... But first check for a Blockage
Aug 07, 2014 | Frigidaire FEX831CS Top Load Stacked...
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Sep 25, 2011 | Kenmore 22422 Top Load Washer
Water overflowing and never shuts off
Jammed solonoid valve open position.....
Nov 02, 2009 | Frigidaire FWS1233F
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Frigidaire wont fill,just keeps draining
Your drain hose must be 36 inches from the ground. Any lower and the water siphons out.
Apr 20, 2009 | Frigidaire Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
