Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Does the ford 3000, have a fuel pump? If so where the heck is it????
How to change oil in a simms fuel injection pump on a Ford 3000
it should not be necessary as the pump is lubricated with engine oil that drains back to the sump or in rotary pumps , is lubricated with diesel fuel
Jun 29, 2017 | Ford Cars & Trucks
Why is it running rich and dying above 3000 rpm?
MATT, COULD BE WRONG PUMP TOO MUCH PRESSURE?? CHECK WITH YOUR FORD DEALER YOU MAY HAVE A SAFTEY ISSUE POSSIBLE FIRE?
Jan 16, 2016 | 2001 Ford Focus
Hi I plugged the scanner in my ford fiesta endura diesel 2001 (y reg) this code number came up P1564 also said injection pump control module requesting reduced fuelling. When starting the car up it smokes...
would try a bottle of fuel injector cleaner ( for DIESEL) sounds like an injector or two are "hanging"open causing too much fuel in cylinder(white smoke) .can be intermintent as heck
May 28, 2011 | Ford Fiesta Cars & Trucks
Not starting which relay controls fuel pump
1994 ford Bronco was starting and running fine. My daughter drove it 3 miles to school that morning then a few hours later she went to start it and it would'nt start. The door chime and all the dome lights, lights on dash lite up as normal and when you turned the key to (start) position you could hear the fuel pump then it just would click and not turn over and start. Jumped the battery that didn't work. Had it towed home and tried a few more times that night to get it to start but no luck. Next afternoon went to check it out again and for the heck of it thought id try starting it. Would'nt ya know it..It STARTED right up? After checking Battery and solenoid..etc I thought it was the starter but now im not sure.
Mar 02, 2011 | 1994 Ford Bronco
Sugar in gas tank how do i fix this
easy, but not fun...
you need to drop the tank, flush the heck and replace the fuel pump "sock".
You might also want to consider just replacing the tank and pump while you are there....better to be safe than sorry
The good news is that the sock is what prevented some serious problems had the sugar had gotten to the engine
Apr 03, 2010 | 2004 Ford F150
1992 ford e150 fuel pump and filter locations please.....
Diesel Fuel Pump
Fig.: Fuel pump assembly components-1995-96 diesel engine
The Fuel Filter is located under vehicle, driver side, below seating area, near fuel tank, mounted on frame rail in fuel line.
Gasoline Fuel Pump
In-tank Pump
Fig.: Typical in-tank electric fuel pump assembly
Fig.: The external pump is mounted on the frame rail
Hope helped with this. Good luck.
Nov 16, 2009 | 1992 Ford Econoline
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
159 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
