Question about Air Tools & Compressors
My 2000 celica turns over but wont start
My 2000 celica gts has been sitting over a year. It got towed by crooked cops in kahoots with a tow company who tried to take ownwrship and i luckily got it back but it wouldnt start from the day it came back and has been in my driveway ever since. Never had issues prior and had a full workup at toyota a month prior to it being towed. Now that I have my license back...I need it to start....I had a coroded batt terminal so that's been replaced and got a new batt, fully charged. My bf did change a relay fuse that a mechanic told him was bad but that didnt fix it not starting. With the new batt and terminal now it turns over like its gonna start (which it didnt do before) right up but it just wont fire. I have full power everywhere except the stereo/radio? Which has always worked prior. My stepdads diagnostic computer found no errors. I also put new gas (it has 3/4 full tank)and some dry gas in......any ideas on why it wont start??
  • jenstruk May 05, 2010
    Do you mean the AIR filter? Or is there really a SIR filter? And this website is pretty confusing...I don't know how this got posted under AIR COMPRESSORS when this is clearly an AUTO issue and I selected AUTO twice! Also the mobile version is seriously lacking.....I originally posted and was trying to view your response on my Andriod phone (TMobile MyTouch), I could not get to it....just loops back to the login screen no matter what you do from the link you get in email....I had to access from a computer to read responses.
    Thanks for your input.....I will try getting a new air filter and plugs today. Someone else posted their daughters car (same make/year model) from May 1 also couldn't start and someone suggested resetting the alarm......there is nothing that shows me how to do this except with the key fob....in the car on the dash there is no toggle switch or button for reset...and when I turn it on the valet mode wiith the key fob it lights up steady in the car like it should. Is there a way to reset it under the hood that you know of and do you think that could have aything to do with it not starting? When we got the new batt terminal on, the alarm did go off....I had to disarm it with the key fob......it's a factory alarm standard witht this model. Also, any idea why the radio would have no power?
    My air filter and spark plugs are brand new, they were changed prior to the tow, they have been sitting with the car but they look pristine. I cannot find any reason for the car not to start, nor any reason for the radio not to power up when everything else in the vehicle has full power and the battery has been fully charged. Could this have anything to do with the anti-theft system? It has no toggle on/off switch nor reset button inside the car and to my knowledge can only be turned on/off with the key fob. I'm so confused and really don't want to have to tow it to the toyota garage!
  • 10,319 Answers
First from sitting so long varnish has built up in the fuel line. Check the fuel filter first by disconnecting it towards the front facing the engine. Turn the ignition to the ON position and listen for the fuel pump running. It should run for 5 seconds when you do this to prime the injectors. If fuel spews out go to the next inspection. The injectors are more than likely plugged up. Auto Zone sells a NOID which is a tester for fuel injectors which are inexpensive. Purchase one and check your injectors. If working electrical wise you should smell gas through the air cleaner.If fuel is present which will have a strong odor check the ignition module and coils next. If no codes were present before it was towed and stored away there will be no codes as of now until you get it running
Posted on May 05, 2010
    President:
  • 2,501 Answers
Check out the sir filter and the carburetta.
Give the plugs a good clean (or fit new ones).
If it still doesn't start then give it a tow.
Vehicles that have been stationary for a long time will sometimes start if they are towed (while in gear-2nd or higher).
It may take some time but is worth a try.
Posted on May 04, 2010
  • David Tolond May 05, 2010
    Sorry, I did mean air filter!
    The radio will fail if the battery dies, (presumably the battery was dead after the car had been unused for a long time).
    You need to enter the code for the radio to allow it to resume normal service. If you have lost your code you will have to approach the car manufacturers local dealer to sort it out.
Shifter damage from tow truck driver
call the garage and ask if a flatbed was used or boom style..why was the car towed in the first place??if it was done by cops.. the tow company will not fix it BUT you can get a decent garage to fix it and send the bill to the towyard that screwed it up..I hate when a towyard.. especially one that excusively tows for law enforcement..screws up cars .. we had a 4wd subaru that was towed without a flatbed..it mbroke the transfer case and subsequently destroyed the car..we fought the tow company for 3 years but finally won..it costs nearly 3000 bucks for a 500 dollar car to proove a point..
Dec 09, 2013 | 2006 Volkswagen Golf 2.0
I have a 92 toyota celica gts with a code alarm installed after market. I went to start the car this morning and there is no power to my radio and the on dash digital clock. Obviously the car wont start...
It sounds like you could have a combination of problems. But, my first guess is a weak battery. The first step would be to charge the battery and then try to start it. If it starts, then take it to a auto shop where they can check the charging system. If your alternator is bad, then it will kill your battery. If your battery is bad, it won't hold any charge and overwork your alternator. If it still won't start after charging the battery, then check the fuses and replace any blown fuses. If it still won't start, have it towed to an ASE certified mechanic. I hope this helps.
Nov 04, 2013 | 1992 Toyota Celica
My 2000 celica gts won't start when it is really
A no-start condition can occur with several different symptoms. Have a clear understanding of which one applies to your vehicle when having the problem diagnosed.
Here are the most common symptoms:
  • Engine will not turn over (or crank over)
  • Engine will turn over (crank) but will not start
  • Engine starts and dies (stalls)
Nov 14, 2012 | Cars & Trucks
Parked my Celica in the underground carpark at work. Hit the electric locks and now the car wont open. Car is on a slight angle. Have put in a new battery, but still not working. Alarm will go off if I...
The fuse to the power door lock/unlock motors has blown. In order to get into the car and start it,
can't you just unlock the door with the key - then start it with the same key?
In the worst case, disconnecting the battery will disable the car alarm, so it can be towed without
the alarm blaring.
May 30, 2011 | 1996 Toyota Celica
I need to replace the water pump and timing belt in a 1990 Celica GTS but I need to transport the car 90 miles before doing it. I don't think the pump is too far gone but I don't want to lose the engine,...
water pumps usually only leak after shut down but no guarantees, you may also want to change oil pump o ring seal. It's right next to water pump, they get old and leak too.Oil pump o-riing and shaft seal very inexpensive from dealer,
Oct 22, 2009 | 1990 Toyota Celica
2000 CELICA GTS DRL WONT GO OFF EVEN WHEN ENGINE IS TURNED OFF
try replacing the relay for the daytime running lights
Jul 14, 2009 | 1997 Jeep Grand Cherokee
TRANSMISSION-HOW CAN I PROVE THAT TOW COMPANY,,, WRECKED MY TRANSMISSION???PLEASE
Get an attorney or they will stone wall on this, the first thing any tow company does when faced with a tow related damage claim is deny it, most people just give up and go away, I have seen this first hand, I know people in the towing business, and for the most part this is their policy, deny, deny, deny!
Oct 08, 2008 | 2000 Audi S4
Timing belt snapped
well if u got a tow start i cant see it runining\
as none of the cams were turning
it might have jumped a bit
and it wont wreck your engine it will have to be retimed with the belt and the gear casing off\\\
and a camry engine will fit depending on the year of the engine
Aug 02, 2008 | 1990 Toyota Celica
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
