Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
TV TURNS ITSELF BACK ON AFTER BEING TURNED OFF
TV TURNS ITSELF BACK ON, AN HOUR OR SO, AFTER BEING TURNED OFF. THE SET JUST COMES BACK ON BY ITSELF, THE ONLY WAY TO STOP IT FROM COMING ON IS TO UNPLUG IT.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
The most common thing is malfunction in your remote control. Try moving the remote control to another closed room, and see if it still does it. If it does... well, I know how to setup a TV to turn itself off after a period of time you set, but how to turn it on? no.
Also something, might be stupid, but I'd tell it anyways, is that someone is fooling you by ór using the remote control, ór having another remote control, and turning it on all the time.
And another thing. By "off", do you mean standby? or actually turned off by pressing the button? Because this is only if it is turned off with the remote control. If it is explicitly turned off by the button, then it might be a malfunction on your tv, meaning you could call the support of the company that makes these tv's, and if it is actually a malfunction, you could get a new tv for free, if your warranty hasn't outdated yet.
That's all I can think of, I hope it helps.
Posted on May 04, 2010
Vizio e322-ar turns on, displays VIA logo, then turns itself back off.
Usually when a TV fails to turn on properly a lamp will flash a number of times which with the correct info guides you in the direction of the fault.
Jan 15, 2014 | Vizio E322ar
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
RCA Colortrak plus. Model# F32672SB Serial # 807560570 Chassis # CTC187CJ3 Manufacture Date Feb 1998 Service # F32672SBFM3 4/21/08- TV worked fine last night. This morning worked for about an hour. ...
It's probably a cracked solder joint in the power supply / horizonal drive stages. As the unit heats up the joint is seperating and breaking connection. It could also be a component failing when it gets hot. Usually the voltage regulator or Horizonal Output Transistor (both mount to heat sinks).
If you know how to solder and want to tinker, unplug the set for a couple days (to let the power capacitors discharge) and resolder and crystalized it cracked joints on the board(s) where the power stages, and flyback transformer are located.
If you decide to operate the set with the back off, please be careful. The high voltage on a TV can be 30,000+ volts.
Hope that helps,
Geno
Apr 21, 2008 | Televison & Video
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Apex pf2025 20 inch tv
timer set in menu options. Mine did the very same thing until I cleared the timer
Oct 13, 2007 | Apex Digital PF2025 20" TV
Tv powers on, then switches off immediately
check out ctechnicians.com and find error codes
Oct 07, 2007 | Mitsubishi VS-60607 TV
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
632 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
