Question about NRS SEAFIT TOOLS Boatyard II Tool Set
Need a replacement 12 volt battery for a Seafit cordless 3/8" drill
Ryobi manuals
YOU CAN GO TO GOOGLE AND DOWN LOAD THE MANUEL.JUST TYPE IN INSTRUCTION MANUEL ROYOBI CORDLESS DRILL 1048-67479CS LITHIUM BATATERY CB 120L YOU SHOULD BE ABLE TO DOWNLOAD THE MANUEL
Aug 12, 2014 | Ryobi Ridgid 12V Cordless Flashlight 12...
Why will my Makita drill not work when the battery is charged?
Could be the the brushes need replaced , how old is the drill
new brushes cost £4.26 inc vat and are simple to fit.
Jul 06, 2014 | Makita 12 Volt Cordless Drill/Driver Kit
Why does ryobi 18V cordless not charge
Please check the LED status of your charger. If both of the charger'sLED flashing, but it can charge a good battery. Than the battery is defective, you may replace a new Ryobi P206 Battery http://www.batteryshops.co.uk/tags_products/ryobi-p206-12-18v-2-speed-drill-driver-battery_6854.html
May 11, 2014 | Ryobi 18v Cordless Drill - P206 18 Volt V
How to remove necessary parts from Bosch PSR 12 cordless drill to recharge the battery?
You shouldn't have to remove any parts, except the battery itself, to charge the PSR12. I did find a breakdown of your drill that shows a 'Battery Retaining Clip' that is a heavy, u-shaped wire that goes into the front of the housing section just above the battery. It may have to be removed to get the battery out.
Nov 25, 2012 | Bosch 12 Volt Cordless Drill
Will a 12 volt slide battery work in my 9.6 volt Black & Decker Firestorm drill. The 9.6 volt batteries don't seem to be made any more. I don't think I paid a lot more for the original drill...
This close to father's day you should be able to buy a new drill for about the same as a battery. The 12v would overheat the motor if you ran it for an extended period.
Jun 13, 2011 | Black & Decker 9.6v Cordless Drill/driver...
Can I buy a new motor for a 12 v Makita cordless? How much?
You need to contact Makita directly. But from experience, it's usually cheaper to purchase new drill than replace parts.
Mar 09, 2011 | Makita 12 Volt Cordless Drill/Driver Kit
I have a Makita 14.4v cordless drill when I put any of the 3 batteries that I have on charge the charger flashes the red LED indicating that they are over temprature is this the charger at fault as I find...
The chargers also go bad... in this case being that all of the batteries are showing bad I would be getting a new charger and trying that out...
heatman101
Dec 07, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
NRS SEAFIT TOOLS Boatyard II Tool Set Logo
214 people viewed this question
Top NRS Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a NRS Home Fencing Expert? Answer questions, earn points and help others
