Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The picture on our tv looks as if it is sinking in the middle and shows double. could this be a bulb?
    Scholar:
  • 70 Answers
The bulb would cause a dark picture or no picture at all. You have a convergence issue and the set will need to be repaired by a technician. Cost would be 150 dollars or more depending on shop rates in your area.
Posted on May 04, 2010
HL-S5087W has become dim in picture
if the colors look good and its just dim its the lamp. usually the lamp will show signs of being bad by looking at the base of the shaft in the middle if its discolored or warped the lamp is bad
Jan 30, 2010 | Samsung HL-S5087W DLP TV
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Aug 16, 2009 | RCA TruFlat 27F520T 27" TV
Picture goes in and out after 20 minutes of air time
welcome to overheating problems
buy a can of component cooler at radio shack then while the tv is on and, not working with the back off; spray the circuit board parts until the problem goes away then install a small 12v computer fan to blow air over the offending overheated chip etc. the cooler is only freon and, will not cause a spark it is safe to use on live circuits
May 29, 2009 | Vivitek V37655 56" DLP TV
Picture is in showing in double vision with colors serperated
bulb is going out. go back to where you bought it to see if warranty will cover it. if not, buy another bulb. ours was like, 40 bucks.
Apr 26, 2009 | Televison & Video
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
Samsung projection tv
This is most likely a convergence problem. Does the picture look like 3D? If so, please confirm that the model is PCL541R and I'll rpovide additional details and instructions.
Dan
Sep 24, 2008 | Samsung PCL541R 54" Rear Projection...
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Picture looks fine in middle but the sides doubles
zenith 55" projection tv. approx 8yrs old.
the right half of picture is normal the left half of picture is blurry or shows double or triple vision.
Feb 13, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
