Question about Canon PIXMA MP620 All-In-One InkJet Printer
Paper jammed how do I get in to unblock
  • 4,041 Answers
Hello there Good Luck
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 04, 2010
Can not get paper to shred
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 26, 2013 | Omnitech Office Equipment & Supplies
Paper jam, what to do
Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 12, 2013 | Embassy Intek Tx40b 4 Sheet Countertop...
|My machine is only operating in reverse
Oct 03, 2013 | Office Equipment & Supplies
I jammed it with too much paper
Sep 17, 2013 | Fellowes W10C Cross-Cut Paper Shredder
I have a samsung CLX 3175 FW printer. Paper jams halfway through print cycle. Nothing in mech to stop - appears to be limit switch fault? If you turn the printer off and on it clears paper
The limit switches are just flags that block or unblock photo sensors. Try blowing the printer out with some canned air, paper dust on these sensors is a common cause of these problems.
Jun 23, 2010 | Samsung CLX-3175FW Multifunction Laser...
The paper jams into the right corner when
if you can get it out consult a technician to do that, because it is the cause of the paper jam and could also damage the drum if you continue.
Feb 06, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Printer will no longer pull paper through or paper jams
There is a blockage. Open the cover and try pushing a single sheet of paper through, this will allow you to identify where it is being blocked. Usually comes from a previous paper jam or something sticky having not completed the cycle, such as a mailing lable. Once identified, a thin letter opener should help you unblock it.
Apr 17, 2009 | Office Equipment & Supplies
How do I unblock my
Try running it in reverse..if that wont clear the paper jammed then it will hav to be taken apart.
Apr 04, 2009 | Royal 10X Shredder
FAX-JX200 Canon
check for paper jam, unplug from power if same servie=ce
Aug 27, 2008 | Canon FAX-JX200
Canon PIXMA MP620 All-In-One InkJet Printer Logo
90 people viewed this question
old marine
old marine
