Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
My computer does not recognize my external hard drive
Computer: MacBook  2.1 OS  X 10.5.8
Ext. Hard drive:  WD2500
  • 416 Answers
Try the device on another PC. if it works then you have a issue with you PC,
Posted on May 06, 2010
My WD2500 external hard drive is not showing on my computer
Most of these externals have no drivers. They are set up to plug & play. If you no longer have the instruction manual, you will need to go on the Seagate Mfg site.
The biggest misconception about the externals is that you have to first format them which is outlined in the instruction manual. The formatting takes a few minutes. Once it is completed the drive will be linked to the computer and you will see it in the formatting window and also in My Computer.
When you format the drive you will also be able to choose which letter the drive will be under. Make sure no other device is assigned the same letter.
If you assign the same letter to two different devices, you may have a conflict and your system will not recognize one of them.
May 20, 2014 | Western Digital Caviar WD2500BB 250 GB...
Why wont my computer recognize my LDHD-UP2 external hard drive?
can you try this sequence
turn off power to both computer and ext drive, after logging off computer
leave ext drive power OFF
connect ext drive to another USB port
turn computer back on let it boot up ext drive is plugged in but no power
once computer stabilizes, then turn power to ext drive on
let me know if this helps.
May 17, 2012 | Computers & Internet
Cant install my GoFlex external hard drive.
try shutting down computer and ext drive
turn off power to ext drive
restart computer and let it stabilize
connect ext drive usb
then turn on power to drive
windows should 'see' it if usb cable and power supply cable are known good.
May 15, 2012 | Seagate FreeAgent Go 500 GB USB Hard Drive
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
How do you use the simpletech 160 gb ext drive with a macbook pro or a macbook
Your external HDD must be MAC OS compatible.
I've it is compatible, just plug it in and it should pop-up
Jun 08, 2011 | SimpleTech SimpleDrive 160 GB External USB...
Macbook Wont Recognize
Try the drive in another computer.
If it doesn't work it is dead...
May 06, 2009 | Western Digital My Book Essential Edition...
Seagate free agent go 250 gb external / macbook pro os x tiger
If you can see the drive in Applications --> utilities --> Disk Utility, then you will be able to reformat it in the Mac OS format and read it.
Good day, Damien
Dec 24, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
My drive is not recognized
I've had this problem before.
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Jun 27, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Hard drive not being recognized
dear ramroot
enter device manager by type devmgmt.msc, select universal serial bus (USB), you can see what problem at USB, right click to conflict port delete the port who's conflict.
restart your computer.
trying to connect your ext. Harddisk again
oke
cropp
Mar 17, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
742 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
