Question about Garmin Nuvi 660 GPS Receiver
Will not aquire satellites
This is a new unit and it goes through the satellite almanac but will not aquire anything.
  • 11 more comments
  • MrEd137 Mar 31, 2008
    My unit has worked great for about 6 months, but on 3/27 it could not get any satellite signal. It had been turned off for about 2 weeks. All other functionality seemed to work fine; it just couldn't find any satellites.
  • dominiek Apr 02, 2008
    same problem - verything works fine but will not acquire satellites. Even after reset
  • dinkal Apr 03, 2008
    If this is a serious solution you peqaople are a joke. No wonder we are going to hell in a hand basket.
  • Anonymous Apr 04, 2008
    wow, so mines just crapped out like 4 days ago. and its been workign fine for 6 months.
    do you think this is a coincidence? maybe garmin is doing some updates to their equipment?
  • Anonymous Apr 07, 2008
    the same happen to me Nuvi 660 very expensive and now very bad device ......
  • Anonymous Apr 10, 2008
    Same here. I live in NorCal, went to San Diego at end of March and it acquired satellites only intermittently.
    Went back home..worked fine. Now back in SoCal and not working again.
    Simulator mode works, all other functions seem to work. Upgraded firmware last month (before 1st trip to San Diego)..maybe this is the problem??? Thinking about trying an external antenna. Reset behind antenna does nothing.
    Dave
  • Anonymous Apr 14, 2008
    Same problem. Worked fine for 8 months, then on March 26, 2008 my Nuvi 650 could not locate satellites on an 8 hour trip. I have since used WebUpdater to install the last software and done a reset, with no success.
  • kuhn123 Apr 26, 2008
    I have just ha the same problem with a Nuvi 660.  I have used it for over a year with never a glitch, and then all of the sudden it can't find a satellite.  Called tech support, said I was way over due for a system update.  Completed the update through WebUpdater, but still will not find a satellite no matter how many times I reset the system and reboot.  Please help!!
  • Anonymous May 07, 2008
    my 660 can not find a satelite ,i'm in So. California, this has been going for the last 2 weeks! Please Help.
  • Speeden71 May 08, 2008
    Same problem. After over a year of flawless use, unit quit receiving satellites. Did the updates and master reset. No go. Called for RMA. They said you are out of warranty but "we will go ahead and do a courtesy repair" no question, no argument. Sent my unit in over night via Fedex. Had a replacement unit back within 4 working days. I think they must know they have a problem with some of the early units otherwise they would not have been so cooperative. So they made good on a defective product. I am guessing they know what the issue is but it probably does not consistantly appear, therefore there is not a going to be a mass notification. Would be bad for business.
  • omanb May 23, 2008
    I too downloaded the updated for my Garmin 660 and in the middle of using it, it just stopped aquiring satellites. Tried reset button and no luck.
  • Anonymous Jun 04, 2008
    I bought my Garmin Nuvi 660 in Sept '06 and it worked well until recently.It now can not track satelites.  Garmin had me upgrade my system s/w, but this destroyed my Maptec data base.  They finally replaced the Maptec data with the new dvd and all went well for about a week.
    Now I have the same problem tracking satellites.  Finnally I see by this post there is a problem with the GPS antennae on the Nuvi 6xx.
    I will send his in ti garmin for repair.
    Jerry
  • dywlc Nov 17, 2008
    I've had my Nuvi 660 for 17 months and it's worked ok until, during a journey, it failed to receive satellites and stuck on that location mid reroute. Despite resetting with the reset button and with the screen reset it's still the same. I've today updated the software today without any improvment. While trying to find a solution I found this site.
    I have sent a message to Garmin Support.
Just buy an external antenna $8 something from amazon and it will solve the problem. This model has an internal antenna problem. Hopefully garmin will resolve this issue.
Posted on Nov 17, 2008
I had this Problem and Disabled Bluetooth. So Far so good. Now finds the satellites.
Posted on May 27, 2008
The problem with the Nuvi 6XX series is the flip up antenna. I rang Tech Support today and they informed me that the antenna is the week link in an otherwise good unit
You will need to have the antenna replaced / repaired
Posted on May 02, 2008
Okay so its a miracle. the nuvi is working again. the same week it stopped working (my previous post) i decided to make to trip to NY (i live in MA). halfway through CT almost getting to NY my nuvi kicked in again and started working perfectly again.
the problem did begin after i did the firmware updates and even after doing the hard reset nothing happened.
but i guess going for a long trip fixes it. well it fixed it for me. back in MA and no issues so far. i dont know how that makes sense but it worked.
Posted on Apr 25, 2008
SOURCE:
Old Tom Tom can't find signal
Replace the battery!. Maximum life is two years. If you have not fully charged it by usb or ac prior to a trip and then connected it to the 12v car outlet before starting the engine the battery becomes damaged overtime.
Battery level determines the time it takes to make a connection. Always keep it charged. Never plug it into 12v car power when starting engine. This will not only shorten the life of the battery, but wiull damage the SIIRF chip.
Please rate my help++++Thanks for uising FIXYA
Jul 01, 2010 | Tomtom One XL GPS Receiver
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
Not receiving satellite signal
It can take 20 minutes or more to download the almanac and ephemeris from the GPS satellites. Just give it time.
May 31, 2009 | GPS
MY GOLF LOGIX HAS WORKED FOR OVER 2 YEARS . NOW IT WILL NOT AQUIRE SATELLITES. OTHER GOLF LOGIX IN MY **** WORK FINE
The GolfLogix 7 had a problem that if you did a reset to factory defaults it wiped out the Almanac in the GPS. This is the Table of where the satelites are. Put in a fresh set of battery's....turn it on and put it out in the open sky for 4 to 8 hours. Sometimes this will work. If not contact Golflogix Tech Support. They ill probable ship you a replacement unit.
Apr 07, 2009 | Garmin Golf Logix GPS
Garmin GPSMAP 60CS displays wrong date
mou exoun dvsei ena gps to opoio mesa einai ola sbismena.
prospathw na tou perasw ena ellhniko xarth alla den mporw...
xreiazomai help.......
Feb 03, 2009 | Garmin GPSMAP 60CS GPS Receiver
I have a Nuvi 200w that I received last December as a gift. This unit takes forever to aquire a satellite. The "DIFFICULY AQUIRING SATELLITES" message comes on 90% of the times I try to use it....
While under warranty.... yes.... Make sure it's been registered on their site before calling them and requesting an RMA number.
- Jim
Sep 17, 2008 | Garmin GPS
Garmin nuvi
If a GPS gets a factory reset, powered off for months, or powered up again in a different country, it will eventually scan the sky for any satellite it can find, and then download a new almanac and ephemeris - which can take up to 12 minutes after it finds the first satellite. This is best done stationary, to minimize the doppler effect until a fix is acquired.
Sep 12, 2008 | Garmin Nuvi 660 GPS Receiver
My garmin c320 wont track any satalites
hi, my garmin c320 has a clear view of the sky but it cant track any satalites i don't know what to do. or if there is anything to do. can some please help me. thanks
Apr 29, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Locked screen
WARNING: A reset will completely wipe the user information off the unit.
To reset the unit you will need to press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER, make sure you release the power button when the unit turns on and a message will appear asking if you wish to clear all user data - select YES to this.
This will completely wipe all data on your unit including almanac data (satellite information). Your unit would then need at least 45 minutes with clear view of the sky to update the almanac and re-acquire a GPS fix which will show your current position.
Your unit would then need at least 20 minutes with clear view of the sky to update the almanac and reacquire.
To reset the unit you need to press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold 'power'. You need to hold both for 30 seconds.
Dec 01, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
277 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
