Question about Kitchen Ranges
What does error code E-6 mean, It is a Convection ovenWhirl pool model #GBD277
  • 17,970 Answers
Generally the E6 error coming with other additional code, and this will be the result of a failed touch pad assembly. Use the procedure below to isolated the issue:
1. Once you have gained access to the touch pad assembly, Inspect the keypad connector for firm a connection. The Key pad will be connected to the rear of the man control board. Check the connectors for a firm connection. Move to step two if the connection is secure.
2. Press CANCEL. If the error code returns after 60 seconds, replace your keypad (also called touch pad or membrane switch). Some models may incorporate the keypad and control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Also can check HERE other details.
Hope this help.
Posted on May 04, 2010
What is a error code F/19 mean?
That error means that the lower oven is not heating fast enough. IT should rise to over 150 in 5 minutes. Check the broiler and the baking coils for continuity. If they are ok then check the radiant heater in the convection fan housing.
May 12, 2015 | LG 30" Built-In Double Electric Convection...
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
What does CFH mean
this is not an error code. it means a call for heat. the pool water temp is colder than your tstat set point
May 25, 2014 | Rheem 266K to 399K BTU Swimming Pool...
I have a Aqua Pro heat pump P130 with error code F5 does anyone know what that means
Error FS?
Unit has started defrost cycle and will reverse operation in 5 minutes.
If coolant has nor res=ached desired temp, unit will shut down and display FS
Other models:
FS can mean not enough water flow in cooling mode.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 25, 2013 | Aqua Pro Swimming Pool Heat Pump 125000...
Error code f1 e3
Try this out,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | Kitchen Ranges
What does F2 mean?
The error code F2 on your GE microwave indicates "Shorted thermal sensor", this condition will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
. It takes a minimum of 5 minutes of convection run time before this code will be
displayed. More information on this error code, as well as other error codes, can be found at
http://www.applianceaid.com/micro_faultcodes.html#gemicro
Best of Luck with your microwave.
Jan 25, 2011 | GE Microwave Ovens
Error Code F1
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 04, 2009 | GE JE1390 Microwave Oven
I have a rome Industries Pool heat pump model 105 showing error code LP???? what does that code mean and what do I do?
I happen to work for Rome Industries and can help you out. The "LP" code on your control board represents "Low Pressure". This is referring to the refrigerant pressure within the unit. The unit is equipped with a low pressure safety switch that when activated shuts the unit down. This could be caused by a refrigeration leak, a stuck thermal expansion valve, or even a faulty pressure switch. If you live within the state of Florida contact Rome Industries and you will receive a free of charge service call including parts and labor as long as your unit is under warranty. If your outside of the state please contact your dealer to handle the claim. Have a good day.
May 01, 2009 | Pool & Spa
Kitchen Ranges Logo
19 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
