Question about Craftsman 24 Hp 48" Deck Yard Tractor
Oil/Filter Change Craftsman GT 3000
I don't know how to undo the oil drain valve to let the old oil out of the mower. Can you shed some light on this for me.
  • sml55 May 11, 2010
    Is it that you don't know how to undo it or that you don't know where it is?
  • 24 Answers
SOURCE: how much oil does it take?
If your mower has a briggs&stratton motor you will need to put in 1 and a half qts. of 30W oil in it.
Posted on Aug 22, 2009
  • 20 Answers
SOURCE: craftsman gt 3000 will not drive.
Hi there, On the Craftsman 3000 there is a pin on the back end of the mower that when pulled outward disengages the transmission so it can be moved without it running. Sometimes this pin will stick. It is connected to a lever on the transmission try to push and pull the pin in and out a few times to see if it will free and engage again. You might have to reach under where the lever is connected to the pin rod and try to move it back into position that way. DO NOT REACH IN TO THE TRANSMISSION AREA WITH THE MOWER RUNNING!!! But the pin must be pushed inward for ingagement. This pin will let the mower just sit there like its in nutral and not go anywhere. Try it!!
Posted on Aug 27, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
Posted on Sep 22, 2009
  • 143 Answers
SOURCE: i want to change the oil what grade of oil do i
Use 15/40 car petrol engine oil.
Posted on May 06, 2010
  • 146 Answers
SOURCE: Oil leak on riding Craftsman LT2000 (Kohler)
Fortunately, the engine oil doesn't go through any rubber hoses, so they are mouse-proof. The oil probably leaked out through an engine seal. Oil on the engine surfaces would smoke when it gets hot. Check your oil level and top it up if necessary, before you run the engine again. The engine can run fine even with a slow oil leak; you just have to watch the oil level from time to time. The leak could be easy to fix - by tightening up a few bolts -- or expensive.
The gas runs through rubber hoses, though. If mice ate through that, I think you would have smelled the gasoline, and the engine wouldn't run for more than a few seconds. But if you see a severed hose, you should replace it. Take it off and bring it to a mower shop or auto supply shop, and buy something the same diameter. Inexpensive.
Hope this helped! If so, please rate my answer, thanks!
Posted on Jun 07, 2010
Testimonial: "Whew, you've eased my mind. I'll head out tomorrow and try your suggestions. I really appreciate your input and the fact that you are willing to respond! Thank you!"
Husqvarna 18538 engine starts smooth but starts popping like backfiring . Trying to figure it's old gas ? Just serviced the machine.
to most owners a service means change oil. plug ,and clean air filter
drain the fuel tank ..new gas
cant see the carby .. if it has one
undo fuel drain nut on side of carby bowl
popping ....check valve adjustments
if no better
you may have a burnt valve
May 31, 2016 | Husqvarna Garden
Lifters problem
my good friend the tap noise you have is not only due to taps failure. Is also coming due to not good oil viscosity and how often you do oil change.My Advice is to do and engine oil flush with a Restore flusher for 40 minutes then drain your old oil drain the old filter and after re-use the old filter with 2 liters of new oil and restart the car and leave it for 10 minutes and then renew oil & filter and use again the Restore friction reducer and every 3000 miles do oil change. If your valves are adjustable do the valve clearance,if not try every 3000 miles to do the same flush way I recommend. It will work unless is a long time working with the tap noise where surely caused damage . Good Luck and let me know with the outcome.
Aug 19, 2012 | 1991 Nissan Stanza
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
How to change oil for a sears gt 6000 kohler magnum 18 hp mower
Most likely on the right side of your mower's engine will be a tube coming out of the base of the engine to about the edge of the frame. There may be a plug or more likely it is a funny looking fitting that will drain the oil. When you clean it up it will have a mechanism that acts like a valve and if you look at the channeling it is not hard to see how it must be operated. Before operating, remove the cap and if available hook up the drain hose. If no drain hose available it will likely make a mess that you must be careful of. The hose is not a necessity, just a nice-ity by keeping the draining of the oil alot cleaner. Anyway, drain into a container and operate the mechanism/valve back to its original position. I am guessing that you will have an oil filter on the other side. This will make a mess too. Spin off the old oil filter and use paper towel or shop rag to make sure that the machined surfaces are clean. Take the new filter and dab some fresh oil on your finger and spread along the rubber gasket. When putting the new filter on, screw it down until the gasket hits the machined surfaces and then snug about another 1/8 to 1/4 turn further. Any tighter may make removal next time very difficult. There may be instructions on the filter box for installtion. Fill up with the recommended amount of oil. There may very well be a sticker under the hood with part number for common replacement parts, it will also have the oil type and capacity on it.
Jul 08, 2011 | Garden
How much oil does it take to change the oil in the lt1000 17.5 hp craftsman riding mower?
The best way to do this is to check that the unit is full of oil. Then measure what comes out when you drain it. Put this amount back in and you should read about a pint less than you need. That is because that is what is in the filter that you changed when you drained the oil. You are going to change the filter, right?
Fine tune the top up and you are good to go.
Feb 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oil change instructions and oil recommendation (lost manual)
Hello, oil to use in the engine depends on engine if it is a Kohler you will want to use 10w30 approx 2qts. The Briggs & Stratton engines use HD30 or SAE30 approx 1.5qts. Use the dip stick to ensure you have the right amount and don't over fill.
To change the oil:
  • run engine about 10 minutes to warm up oil so it flows better
  • at the bottom of the dip stick there is either a valve or plug
  • open the valve or plug and let the oil drain (I use an old gallon oil container with a funnel) leave the dip stick out
  • while the oil drains; change the spin on oil filter
  • once all the old oil has drained replace the plug or close the valve
  • wipe down the funnel and use it to refill the new oil
  • use the dip stick to ensure proper fill level
I also recommend that you replace the air filter at the same time, if the engine can't get air is can't run efficiently.
If this is helpful please vote yes, Thank You!!
Sep 15, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Engine piston
SOUNDS like you have done a big end and when the oil gets warm the oil gets thinner and so doesent lub the engine so good and what you can hear is the piston either hitting the head or the bigend worn bearings on 1 cylinder banging on the crankshaft as they have to have oil there to lub and to pressure the bearings while running SO WHEN you get it rebuilt change your oil to a 20W40 in winter and 20W50 in summer and change it every 50 hrs for your own sake.
Oct 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Crafsman Eager 1 6.75 HP lawnmower wont start
I have an Eager 1, as well and when I try to pull the cord it does not turn at all. It's stuck. I hit a tree root and since then I have had problems with it. I have 2 mowers so it was not used last year at all. Gas was drained and it was stored in a shed. Anyway, I know nothng about mowers other than spark plugs, gas, oil, sharp blades and filters. Is the motor seized? Thanks
Feb 15, 2009 | Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
1,305 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
