Question about Maytag MMV5156AAS Microwave Oven
Touch pad don't work, start and 30 sec add pad don't work. all other seems to work. What is the problem?
I must have steamed out the sensor panel. there is know response what so ever. It's dead.
Posted on May 13, 2010
  • Maytag Master
  • 9,098 Answers
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
Would like specifications to JVM1850SM2SS
  • 1.8 CF Oven Cavity
  • Electronic Touch Controls
  • 950 Watts
  • Display On/Off Yes (option pad)
  • Add 30 Seconds Instant-On
  • Cooking System CircuWave®
  • Defrost - Auto / Time / 1 lb. Quick Defrost
  • Delay Start
  • Express Cook Instant-on 1-6 minutes
  • Instant On Controls
  • Micro / Time Cook I & II
  • 10 Power Levels
  • Wire Oven Rack
  • Cooktop Lighting - Bright/Night/Off
  • Demo Mode
  • Interior Oven Light - Halogen
  • Night Light (option pad)
  • Child Lockout
  • Easy Mount Installation
  • Exhaust Fan 3 Speed Plus Boost (315 CFM)
  • Cooking Complete Reminder
  • Timer (On/Off)
  • Reminder (24 hr)
  • Sound Volume Control - 4 levels
  • Sensor Controls
  • Beverage Instant-On
  • Popcorn Instant-on
  • Potatoes Instant-on
  • Reheat Instant-On
  • Sensor Controls
  • Vegetables Instant-on, 3 pads (canned, frzn, fresh)
  • SmartControl System
  • Clock Plus AM/PM pad
  • Concurrent Programming
  • Custom Pad
  • Electronic Scrolling Digital Display - 2 line
  • Help Pad
  • Variable Scroll Speed - 5 Speeds (Options Pad)
  • 14.25 " Turntable - Glass Recessed
  • Turntable On / Off
  • 2 Wire Oven Racks; 2 Positions
  • Recirculating Charcoal Filter Kit JX81B
Dec 15, 2014 | GE Microwave Ovens
GE Spacemaker JVM1450AA001 started beeping then said to enter the time, which I couldn't enter because none of the panel buttons work, and is now showing F3 code? Sounds like the touch pad pa
Yeah, I think you're right, sounds like a shorted touchpad to me. Can you fix it? I don't know. You will have to disconnect and re-connect quite a few cables and connectors from the control panel. If you've never done that kind of work before, then I would not recommend that you try; it would be all too easy to damage something (like pulling a wire out of a connector, or inserting it wrong.
Oct 18, 2014 | Microwave Ovens
Why are GE Profile JT930 touch pad numbers not working?
Seems problem with the touch pad. Try replacing the same.
Aug 16, 2014 | GE Appliances 30" Trivection Built-in...
Microwave won't start
The door interlock may have failed.
Mar 24, 2014 | Hamilton Beach HB-P100N30AL-S3 - 1.1 CF...
Check the fuse usually a 25 amp appliance fuse behind key pad
Mar 18, 2014 | Whirlpool MT2110SJQ 1100 Watts Microwave...
Touch pad doesn't work
Your touch pad is connected to your board with a ribbon wire, it has probably come loose. Unplug the unit and remove the face plate. Pull it back and you will see the wire, it looks like a ribbon, push it in tight, replace the face plate and it should work properly. I see this happen all the time.
Sep 12, 2017 | Maytag Microwave Ovens
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
Purchased an over the counter microwave oven, model JVM1540 DM2WW. It only seems to have 30 seconds as a minimum setting How can set the time at 10 sec. or less? (short of chosing "add 30 sec" and...
Went to the store where I bought it, and talked with a sales rep. in the appliance dept.
After paying $ 198 for the microwave and...$ 159 to have it installed, I was not about giving $ 9.99 more to answer a simple question.
Apr 04, 2008 | GE Microwave Ovens
Key Pad only works on some numbers. Others do not respond when pushed
Unplug the unit. Generally, remove the screws inside the door that hold on the faceplate. Inside, it will become rather obvious how to detach the keypad from the main circuit board. Note that some of the screws are longer than others. Carefully unplug the wire loom from the board. Note that these plugs have a small movable section. Flush to the board is lock...up is unlocked. Make sure when you push the loom in that the section is up...then push it down. By the way...before you buy a new part, unplug each connection related to the key panel and reinstall. It may just fix it.
Dec 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5156AAS Microwave Oven Logo
101 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
