Question about Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit
Battery charger Delta model CL180C doesn't turn on (neither alone nor with a battery)
  • 10,865 Answers
Hello Alfred. I have that same exact drill and charger. Your charger is shot and there is no fixing it.
You can replace it at http://www.dewaltservicenet.com/
The problem will probably be the cost of a new charger. Good luck with it. Joe
Posted on May 04, 2010
How do i fix charging problem in hp Compaq Presario laptop
If you are using a pattern charger, there may not be enough current to power both battery and laptop.
Sep 26, 2016 | HP Computers & Internet
I need a CL120C cordless drill charger
Delta Battery Charger ' eBay
www.ebay.com/bhp/delta-battery-charger
eBayFind great deals on eBay for Delta Battery Charger in Power Tool Batteries and Battery Chargers. Shop with confidence.
Oct 07, 2015 | Drills
Delta CL 180 model charger turns on when you plug in and the yellow light comes on but when you put the battery in to charge the lights go out?
If all lights go out after the battery is inserted, the charger has entered pre-charge mode. In approximately 5-10 minutes, the orange and red lights should turn on indicating that fast charge has been initiated. If all lights remain off after 15 minutes, remove the battery. The orange light should glow. Reinsert the battery. If the orange light goes out when the battery is inserted and all lights remain off for 15 minutes the battery should be replaced.
Hope this helps.
Apr 09, 2012 | Dewalt Drills
Need manual for rival soft serve ice cream maker model 8150
Rival doesn't have the model 8150 listed, but here's the model 8151 manual. Maybe it will be close enough to help.
Aug 07, 2011 | Rival Soft Serve 1.5 Quart Ice Cream Maker
My laptop charging port is not working properly. My Charger is running properly but the charging port of the laptop is not working.It is not getting charged.Now the laptop is totally off and now i cant...
There are three possible parts of the computer which cause the problem.
1. ac adapter or charger
2. battery
3. motherboard
The charger is working fine which leaves the battery and the motherboard to be the possible reasons for that certain problem. What you need to do is to check which one is really the part that's causing the problem.
Here's what you need to do:
1. Remove the battery from the laptop.
2. Turn the computer by using the charger alone. If it turns on then, the battery needs to be replaced. If it doesn't then it's a motherboard problem which is a very complicated situation. You need to see a computer technician for a motherboard problem.
Apr 19, 2011 | Compaq Presario CQ40 Series Laptop Charger...
I have a Delta 18v charger model# CL180C. The unit gous on but does not charge the battery. I can not get the battery to stay on the yellow/red charging function. Any suggestions? Thank you Joe D.
If the charger doesn't read the battery and tell whether it is good or not, then the charger is probably at fault. It has a date code or a date stamped on it, if it is 2 years old or older, trash it. If it is less than that, take it back where you bought it, if they don't replace it, buy a Ryobi, all tools guaranteed for 2 years, all batteries, chargers, saws, everything they make, I don't buy anything but Ryobi, and we have a lot of tools. My whole truck is full of cordless tools. You can look up the code numbers on line, and check out the warranty.
Feb 28, 2011 | Garden
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
Probably battery, although that should be orange not red..
Remove battery and try it on AC alone, if that works, it was a damaged battery halting the process
If it does not, check the charger's tightness in the charging port, if sloppy or loose, this will need replacing.
Some Dell's are VERY picky about the charger, if not the exact model specified, they will not charge the battery
If none of the above, remove battery and test with another Dell charger of the same spec, if this also fails to work and you are sure the light is red, you have a problem with the motherboard. Commonly the charger power board fails on these.
Jan 06, 2011 | Dell Inspiron 1545 Notebook
My laptop is plugged in but will not turn on. When I try to turn it on the battery light flashes. Does the battery just need to be replaced?
Try to turn on the computer with the battery alone... Then if the adaptor alone.. Check which is the one defective.. Replace the parts according to that...If you have a different charger and a battery try with them also...
Oct 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
Charger problem CL180
Call Black and Decker customer service, or better yet a DeWalt service center nearest to you.  Tell them you have this kit.  They are willing to give you 20% off a new DeWalt cordless kit.  Parts are non existing for this Delta Shopmaster set.  Black and Decker bought Delta just after this set was on the market.  I have searched and searched, all I can find is battery rebuilders.  I had the exact problem you had with the charger.  I tried to retrofit other manufacturers battery chargers, to this sets batteries, and still no dice.  I would call the nearest DeWalt/Black & Decker/Porter Cable/Delta service center and talk to them about a trade in on your units.  Something for this set is better than nothing I guess?  I think I am going to go this route with my set.
Sep 26, 2009 | Drills
Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit Logo
1,584 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
