Question about AudioBahn DUB Mag Audio DUB2502 Car Audio Amplifier
I have a dub2502 amp with the red protection light on and will not go off. The amp is a 1100 watt peak amp @ 4 ohms and my sub is an Audiobahn 1100 watt peak, 4 ohm. wired perfectly. so how do I fix the protection mode problem?
    Scholar:
  • 70 Answers
The unit will need to be repaired by a technician. Most likely you have a bad transistor that is causing the protect mode to turn on. The only way to get the protect mode to turn off is to remove the bad part.
Posted on May 04, 2010
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
I want a reliable system.
if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
May 19, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
I have a 650 watt lanzar vector amp hooked up to 2 1500 watt sony subs. my amp is turned up half way and it frequently shuts off and the red protection light comes on.
the problem is that you must have your subs wired to a lower impedance than the amp can handle. Wire your subs to 4 ohms, or get an amp that can handle 2 or even 1 ohms and crank it and enjoy!!!!!!!!!!!
Sep 19, 2009 | Car Audio & Video
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Audiobahn DUB Mag Audio 2502 Amplifier
If the protection light is on, the amplifier likely has shorted output transistors. To eliminate other possible causes, read through the following page.
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Aug 07, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
DUB 2502 Protection Mode help
The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Audiobahn sub settup
audiobahn.com has a tech support with diagrams on thier website check it out
Jun 03, 2008 | AudioBahn AW121T Car Subwoofer
Amp stuck in protection mode.
check to make sure your ground wire is attached to a clean metal surface no more then 18" away from amp. check all wires to ensure none are touching other terminal. all else fails remove one sub and see how it play, if its works great switch subs. could be a defective amp. if it is the amp and you payed for it with a credit card or bank card you can do a charge back from the bank to get your money back if the store wont replace it. thell the bank "you want to do a charge back cause it wasnt as discribed).
Nov 10, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
DUB2502 amp
you probably have the speakers set to where it ecxeeds the ohm load limits. its only 4 ohm stable when bridged and two ohm stable when ran using two channels. so either run the speakers at 8 ohms each parallel or just hook one speaker to eack channel. if you do not know what i am talking about then just email me at grandam88@hotmail.com and give me the speaker specifications.
Oct 07, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Car Audio & Video Logo
306 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
