Question about Radio Shack Pro-83 Scanner
Cannot set the signal stalkel function - Radio Shack Pro-83 Scanner
  • 99 Answers
Pess the function button + the stalk (eye with cross hairs) to enable the function.
Posted on Aug 31, 2010
Hi when i go over 70mph a constant beeping goes off in my 2007 corsa 1.2cdti how do you turn it off please?
Owners manuals Here are the manuals it is pretty descriptive as to how to do this.
Pull turn signal stalk and wiper stalk
simultaneously to the steering
wheel until you hear a confirmation
signal (approx. 3 seconds).
? The miles display shows P1.
Push the turn signal stalk (left) up
or down and select the desired
function p6
Push the wiper stalk (right) up or
down and select status On or OFF,
or input a value for speed (P6) or
value for volume (P7).
? Pull turn signal stalk (left) and wiper
stalk (right) simultaneously to the
steering wheel until you hear
a confirmation signal (approx.
3 seconds).
The selected settings are now stored
for the key in the ignition lock. To
activate and deactivate the functions
and set the functions selected, please
see the relevant sections.
Repeat the procedure to program
Jan 31, 2015 | 2007 Opel Corsa 1.2
Our jvc tv model #HD-70GC78AAA says weak signal
Its possible its the signal source (cable, satellite etc) if using the coax input--the tuner in the set could even be bad.
If rear inputs for DVD etc function well you may be able to get around this with a box with outputs for those inputs on the set--bypass the problem.
Dec 16, 2012 | Televison & Video
Keeps showing no signal
I would first double check all signal connections to the set in case that is the issue.
Also for peace of mind and to rule some things out does the set function with a DVD connected to one of the rear sets of audio/video jacks or not?
If possible let me know what is connected and where on the set for regular TV viewing.
Dec 05, 2012 | LG 42LC2D 42 in. LCD HDTV
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How do i turn off the sound on the alarm
Setting Audible signal
This function gives an audible signal when the coffee is ready. The factory setting is "On".
  • The display (q) will show " " with the current time.
  • To turn off the audible signal :
  • Press prog button then the 1 - 3 cup button (p).
  • The display will show "YES": indicating the audible signal is on.
  • To turn the audible signal off:
  • Press the 1-3 cup button again.
  • The display will show "NO": the audible signal is off.
  • Press prog button to confirm.
Sep 24, 2010 | Krups FMF5-14 Stainless Steel 10-Cup...
I NEVER HAVE HAD A PROBLEM WITH MY SCANNER UNTIL NOW,A SYMBOL INDICATING SCAN POPPED UP IN FAR RIGHT CORNER. AND EVERY TIME IT IS RECEIVING IT LIGHTS UP AND MAKE A BEEPING SOUND. AND THEN THE WORD...
Press the function key + the symbol that looks like an eye with cross hairs (signal stalker mode) and turn the function off. To set the options in signal stalker, press function + signal stalker for 2 seconds.
Jun 25, 2010 | Radio Shack Pro-84 Handheld Scanner
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
'left' or 'volume down' function appears to be
The volume down button on front of TV is stuck down or the switch is bad.
May 02, 2010 | Televison & Video
I have a WD62825, it lost power while watching. There is power at the plug in.
Is the grreen light on?..or can be switched on via remote? Plug it out then back in. Green light flashing? If so...you have lost input signal or the tv has reset itself to another input (non functioning). Use Remote to set input (via Net Command) to functioning signal. If the Green light NEVER comes on...it may be major system failure. Be sure remote is set to "TV"
Jun 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
If the red
Sorry guys but I went and bought a replacement set top box for $20
Sep 30, 2008 | Televison & Video
Radio Shack Pro-83 Scanner Logo
32 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
