Question about HP Pavilion dv9000z Notebook
CD/DVD Drive stopped working. When I insert a
CD/DVD Drive stopped working. When I insert a black CD-R to copy files, nothing happens. The device manager does not show a CD drive. How can I fix this problem?
  • 553 Answers
Unfortunately, if device manager is not reconizing your CD drive, your drive has gone bad and needs to be replaced.
Posted on May 04, 2010
  • HP Master
  • 7,733 Answers
Or open your PC and check if any cable are disconnected.Also disconnect the CD drive then power on, the power off, re-connect the drive and restart to see if it recognize.If not the drive is bad.
Posted on Sep 24, 2012
Tip
The Installation CD Does Not Start Automatically in Windows XP
This tip answers issue regarding CD's that come with your HP printer. <span>If after putting the installation CD into the CD drive, the software does not automatically start installing the software you can do either one of the following.</span> <span>1. On your pc, go to Start, click My Computer, right-click the CD-ROM drive then click Autoplay.</span> <span>2.If nothing happens, check whether the Autorun feature is enabled, if not enable <b>Autorun</b> by going to t</span><span>he <b>Control Panel</b>, double-click <b>System</b>, go to <b>Device Manager</b> and click the plus sign next to CD-ROM Drive entries. Right-click the name of your CD-ROM and go to <b>Properties</b>. In the<b> Properties</b> screen, go to <b>Settings</b> and check the box next to <i>Auto Insert Notification.</i></span> <span></span><span>Or</span> <span>Click <b>Start</b>, then <b>Run</b>, type <span>gpedit.msc.</span>Click <b>Administrative Templates</b> under <i>Computer configuration</i>. Click <b>System</b>, then click <i>Turn off Autoplay</i>.Right-click <i>Turn off Autoplay</i>, then click Properties. Under <b>Setting</b>, click <i>configured</i>.</span> <span>3. If any of the two won't work you can manually install the HP software CD. To do this, c</span><span>lick <b>Start</b> and then click <b>Run. </b></span><span>Click <b>Browse</b> and then select My <b>Computer</b>. </span><span>Click the CD/DVD drive. </span><span>Double-click the <b><u>setup.exe</u></b> file.</span><span>If nothing happens, it may be because CD drive is unable to read the CD.</span> <span>4. Check whether the CD drive is working by playing other CD or DVD.</span><span>If music CD/Video CD is not working then there is an issue with CD/DVD drive, contact Computer manufacturer.</span><span>If the Music/Video CD works with the CD drive, clean the HP software CD using a soft cloth damped in distilled water and wipe the CD with lint free cloth.</span><span>Reinsert software CD and wait until it auto plays.</span><span>If it fails again then try inserting software CD in a different drive if any.</span> <span>5. </span><span>If CD is not working in any of the available drives then copy the files to the hard drive.To do this,c</span><span>lick <b>Start</b> and open <b><i>My Computer</i></b> or double-click <b>My Computer</b> on the Desktop.</span><span>Double-click <b>C:\</b> or <b>D:\</b> , assuming C: and D: are the computer hard drives.</span><span>Right-click the empty pane in C:\ or D:\ of <b><i>My Computer</i></b> and select <b>New</b> .Then click <b>Folder</b> .</span><span>A new folder is created. Rename the new folder <b><i>HP Driver</i></b> .</span><span>Right-click <b>Start</b> and then click <b>Explore</b> to open Windows Explorer.</span><span>Locate the CD-ROM drive letter in the left pane of the window and select it so that the contents are displayed in the right pane.</span><span>Click <b>Edit</b> in the <b><i>File</i></b> menu and then click <b>Select All</b> to highlight all of the files and folders.</span><span>With the files still selected, click <b>Edit</b> and then click <b>Copy</b> .</span><span>Close Windows Explorer. Open the HP Driver folder created in step 1, click <b>Edit</b> , and then click <b>Paste</b> to copy the files to the HP Driver folder on the hard drive.</span> <span><br /></span> <span></span><span>If while copying, a <span>Cannot copy from source disk or drive</span> or <span>Cannot copy specified file</span> error message is displayed, then check the functionality of the CD drive by using a different CD. </span> <span><br /></span> <span>If other CDs work correctly, it means there is an error reading the HP software CD.</span> <span><br /></span> <span></span><span>If the files cannot be copied from the CD, the CD may be defective. In this case, you can either download a software or order a CD at <u>support and drivers</u> page of hp.com.</span>
on Apr 03, 2011 | HP Officejet 5610 All-In-One InkJet...
My problem is that almost all of my CD's cant be read by my DVD rom drive in my computer, when I insert the cd it keeps on blinking until it stops and nothing happens, I tested it on the laptop and it...
it sounds like the dvd drive without ,,that's kinda what happened to our cd drive last week, I bought a cd drive at walmart,,but they also have good one at best buy
Aug 26, 2011 | Acer (KV.16X04.007) DVD Drive
Drive non responsive
Hi, it sounds like a bad CD/DVD. The DVD drive has a small hole in the front that you can use a small paper clip or tool that has a small tip and insert it into the hole and it will eject the DVD drive drawer then you can try another DVD or CD. Make sure the DVD or CD is clean and there is no scratches on it. You can clean the DVD or CD with a soft clean cloth and even buff out small scratches. Hope that helped.
Dec 14, 2017 | Fujitsu Siemens SCALEO C772 17" CRT...
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Please insert a disk into drive
You can only copy files to a blank disk by using programs like NERO or by using a re-writeable disk like DVD-RW which you can format and use it like a hard drive. You need also burner not an ordinary DVD or CD player.
Aug 07, 2008 | Computers & Internet
Combo drive not reading DVD
my combo drive also not reading dvd :(
Dec 23, 2007 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Acer aspire 5102 with philips sdvd8821 dvdram drive
alright. bubul78, your post is in no way shape or form a solution for the problems given by other users. I too have a acer laptop with the philips dvd drive in it, device manager detects the dvd reader and says it is running with no problems. i can hear the drive read the cd when inserted, tho when trying to access the drive through my computer the window hangs at the hourglass for a min or so, then says please insert a cd. only solution is that something is physically wrong with the drive. ok so solution found, replace the cd drive. but where is acers sight to order replacement parts? poor site navigation in my opinion.
Nov 01, 2007 | Acer (KV.16X04.007) DVD Drive
Benq CDRW 5232X drive, running on Win XP.
The laser lens in your drive might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
HP Pavilion dv9000z Notebook Logo
151 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
