Question about Bowflex Treadclimber
Treadclimber tc5000 wiring diagrams - Bowflex Treadclimber
5 Suggested Answers
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Posted on May 30, 2009
SOURCE: Black dust coming out
I just got a BowFlex TreadClimber TC3000. I have been using it for about 1 week and I noticed black dust coming out of the back. It was near the treadles. I called BowFlex and they said that this is normal during the first few weeks of use. This is the coating coming off of the treads. They said I could vaccum it up. They also mentioned that they only time to really worry is if there is white dust. That is the actual treads wearing off. Hope that helps!
Posted on Jul 27, 2009
SOURCE: one treadle is rubbung on the upright
The rear bolts are loose. I had the same problem and found the four 3/8" bolts loose. You need to take the rear side covers off first then the rear cover to get to the bolts.
Posted on Dec 30, 2010
ercupa190
  • 12223 Answers
SOURCE: how do you replace the breaker on a tc5000
VERY EASE DISCONNECT THE POWER CORD.
Disolder the wires with Solder Gun, change the breaker and again put solder in the terminal, please do it with carefully, and very tight the terminals.
the breaker is to side from main switch.
sincerely.
Posted on Nov 30, 2011
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458
In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual
Good Luck!
Feb 02, 2016 | Bowflex TreadClimber TC5000
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
Start shuts down machine and blows circuit breaker
see the video attached. and proceed according. However you must test the power cord for short circuit. some wires is touching each to another. Or the outlet wall the wires are loosing touching each to other and blowing the c.breaker, or call some electrician for to fix it.
God bless you
Oct 17, 2013 | Bowflex Tc5000 Climber Treadclimber...
Power switches off after 15 to 20 minutes use
test the power switch for defective use the vom
2) test the c. breaker for defective use the vom
3) test the power supplier see the diagram attached.
God bless you
Aug 25, 2013 | Bowflex TreadClimber TC5000
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
My tc5000 keeps failing the cal can you help
Try again RUN the software calibration. and adjust the REED SWITCH, and Speed Sensor, test it, clean it, and tight the plug or connector from UPPER board vs lower board.
God bless you
Nov 16, 2012 | Bowflex Treadclimber Tc5000 Tc 5000 W In...
Bowflex wont calibration or pass calabration
1= do not panic
2= Lube the deck belt
3= lube the roller bearing
4= adjust the REED switch see the diagram attached, clean and tigh the wires connector very well
5= lube the motor elevation very well gear and shaft.
6= adjust the potentiometer of elevation motor,
7a readjust again the speed sensor, see the diagram attached,clean it and tight wires connector very well.
7= Run again the software calibration for diagnose and troubleshooting
see the block diagram and fix it , maybe the main motor board is faulty, test it with the RUN s.calibration. God bless you
7_8_2012_2_00_09_pm.gif7_8_2012_2_01_02_pm.jpg7_8_2012_2_01_21_pm.gif7_8_2012_2_01_41_pm.gif
Jul 08, 2012 | Bowflex Tc5000 Climber Treadclimber...
How do you replace the breaker on a tc5000 treadclimber
sincerely.
Oct 09, 2011 | Bowflex Treadclimber
Hey we moved my treadclimber tc5000 and now it won't power on. Cord is plugged in and outlet is good
there could be several reasons why but i think that you have bumped a wire loose somewhere else. look and see on the control board that wires havent come loose. also check the wires from the console down to the control board. i have fixed several treadmils from people complaining about this same problem.
Jan 28, 2011 | Bowflex Treadclimber
Bowflex Treadclimber Logo
254 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
